Home > General Chat > why won`t my car blow up ????????
minimark
Member #: 19
newcastle
bit off target this , C5 2lt hdi , uses loads of water , now starting to over heat (twice so far) and spitting all the water out , but it just keeps on running , starts first time , pulls well .. is it just a matter of time before it goes BANG????????????
cracked head or something?
depends where the crack is/whether its just the gasket leaking into the bore. i'd yes just a matter of time *happy* if is spitting water into the cylinders you just have to wait for it to hydraulic *happy*
ive got a collection of 3-4 conroads and pistons from engines that have hydrauliced (sp). they are impressive, i'll try and get some pictures.
minimark
Member #: 19
newcastle
its a taxi on the road 8 hours at a time so maybe its spitting water into the bore and out the back ... just thought , the top hose pressuries up as normal
minimark
Member #: 19
newcastle
obv its not worth reparing so looking for a new work horse
when you want them to blow, they wont.
when you need them to work, they wont.
rad seal it it will run for another 200k ...lol
Ben H
Member #: 184
Melton Mowbray, Pie Country
Funnily enough my 20lt HDI has just started loosing water, very slowly at the moment. I am guessing it is the head gasket. Mmmm rad weld, worth a try I think.
http://www.twin-turbo.co.uk
minimark
Member #: 19
newcastle
check your fans are actually cutting in , mine arn`t so its off to the doctors for it today
Ben H
Member #: 184
Mine never get hot enough for the fans to cut it. It is just slowly losing water. Could be a leaky hose, but it is difficult to see in the dark and when the engine by is constantly wet.
minimark
Member #: 19
newcastle
well mine is as good as dead .. 50 mile range and then over heats
