Home > Help Needed / General Tech Chat > Fuel lines
m4dn35s
Member #: 243
Portsmouth
Hi all,
I know this has come up before but i jus wanted to check. Im gonna be running the fuel lines shortly and was wondering would it be safe to run them through the inside of the car underneath the carpet in copper tube? or would it be safer to run them under the car?
Cheers matt
WooHoo Passed it's MOT!!!! One of the cars in The Portsmouth Mini Turbo Massive!!
sauber 200
Member #: 245
ok either way,but easier to fit underneath following original lines,
adam1330
Member #: 238
essex
yeah i agree, done it both ways and underneath turned out to be the easier way, much neater aswell.
m4dn35s
Member #: 243
Portsmouth
ok i expect il do it underneath then. Where is the cheapest/best place to get braided petrol line? only need a bit of it for when it goes through the floor in the boot.
Or can you buy jus the overbraid?
cheers matt
evolotion
Member #: 83
Glasgow, Scotland
use normal fuel lines and overbraid if u want to show off... or jsut normal(injection, nice high pressure rating) fuel pipe if ur cheap like me :)
Denis O'Brien.
m4dn35s
Member #: 243
Portsmouth
yer i have the copper microbore pipe and normal rubber high pressure fuel hose. but was worried about it chaffing on the bodywork as it goes into the boot.
Use rubber grommets. Dont leave it to just go through on its own. Grommets are pennies. Much cheaper than over braided plus id still use a grommet with over braid.
evolotion
Member #: 83
Glasgow, Scotland
seconded, if the bradded pipe chaffs(sp) it wil wear away and fail just as easy as a rubber pipe.
Denis O'Brien.
