Home > General Chat > More clutch plate confusion
So, here is the MED / Minispares plate that you can buy as a much cheaper alternative to the AP plate:
PaulS told me in this post it has an effective 108mm ID on the friction area, and so began discussions on area vs torque:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=271624
Well, unless I'm missing something quite obvious, all of that is irrelevant as the ID of the backplate and clamping plate on the Verto at least (and I assume the pre-verto is the same - but don't have one on hand) is 130-135mm...
So, that means these Minispares / MED plates have the 25% or whatever of the lining sitting in fresh air - doesn't it?
I think the manufacturer of these plates make other plates - and the pucks (kind of) match the OD of the 'other' application - the ID is basically ignored here as it is sitting in fresh air...
Edited by turbodave16v on 15th Feb, 2009.
You are correct:
The inside diameter of the hole allowing for the chamfer is 134mm.
So it already has the larger effective radius and higher torque rating *happy*
Perfect picture... Thanks!
btw - I called AP on Friday, trying to glean some infor about lining pressures. I didn't get my answer, but they did reveal that they assume / use the same friction co-eff for the race/rally orgnic to their metallic... Goes against what I'd have thought - but this much mean the organic is a pretty good material.
Dave if the same person told you that that told me there was no difference in overall weight and inertia of there sintered race plate for the mini and that of there solid sintered 7.25" plates for inline applicarutions then he will have been either very missinfirmed , trying to throw you off the scent, or just plain bullshitting,
the mini sintered plate ids a great deal heavier than the aformentioned inline plate, and i beleive that 5 puck plate to be heavier still,and it looks rather concklusive that anyone using one is happy to carry around the extra weight for no gain whatsoever,
carl
Carl - I never said weight / inertia... I was quoting the friction value?
Out of interest, ive just weighed a couple of new unused plates.
The C-AHT596, solid centered, road rally plate - 581g
The five fingered sintered paddle plate pictured above - 794g
So what Carls says is very true.
However, when you are producing more torque than can be put through the tyres to the tarmac, engine inertia is largely irrellevant.
That's good info Paul. Thanks.
i know that , my main point was about tyhe AP employee,
i just threw the other thoughts in for free,lol.
but i htpought we'd been down this route before , the friction has no dimention or whatever its called,
and Paul what you say has a certian amont of truth, but as far as myself ia concerned the lighter the whole moving ,otating oscillating parts the better, anyway theres allways bigger tyres,lol
carl
carl
Yes, I was just thinking that the twinnie on slicks would benefit from a lighter clutch plate.
But something like Jimsters car with 230 odd curly wurleys, which I presume that Dave is designing for, would not see the same benefit.
one other thing that just cannot be right is the five pucks , at any time there is gonig to be uneven pressure on them, due to the three points of contact between the cover and backplate,
a solid plate and the 6 puck will have equal psessure all the time at the three lug points ,
Interesting point there Carl.
I also think that this may explain why paddle plates sometimes squeal on take-up.
carl
I'm confused, if friction is dimensionless what advantage in there in fitting bigger tryres?
carl
because i say so, that and a big fat bastard sitting on the can box,lol
Once the surfaces start slipping you go from static friction to kinetic friction.
The laws of static friction were developed in the 1700s so did not consider spinning tyres *happy*
My theory is that with kinetic friction,temperature plays a major part in determining the coefficient.
So a bigger tyre grips better because it does not get so hot and maintains it's coefficient. Likewise a narrow tyre runs hotter etc.
Same for a clutch. The more the surface area, the better the clutch is at maintaining grip.
beat me too it again,lol
All i know is there is need for a smooth pulling away clutch that can take big torque, over 250 + would be helpful.
Make a centre hub...and get someone to make some carbon discs, and adapt a verto to something like this.
These carbon clutches are amazing in real life.
I belive the 6 puck ap plate aso overhangs the middle of the friction surface...
i seem to remember jason g's old plate having a raised bit in the middle (albeit on a pre verto setup)
from a rotatinal inertia point of view i would look at the 190 mm verto scintered plate, although it is a larger diameter it only has 4 pucks, but they will not over hang causing possible issues by wearing is an odd shape,
carl talbot
Member #: 1323
get down the gym and work that left leg :)
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
med steel back plates certainly not have std 125mm pre verto ID
