| Home > General Chat > Bad BAd Bad air Filters | ||||||
15th Feb, 2009 at 11:34:53pm
Air filtration is a problem with an 8 port and a round nose, space is tight.
15th Feb, 2009 at 11:35:31pm
uhmm fail.
15th Feb, 2009 at 11:39:02pm
works now Edited by Sprocket on 15th Feb, 2009. On 26th Oct, 2004 TurboDave16v said:
15th Feb, 2009 at 11:51:46pm
if you are buying a new air filter(s) steer clear of hks too especialy there mushroom filters when i get home ill try digout the results of a test we had done in the supra club iirc piperx came 3rd worst Edited by Brett on 15th Feb, 2009. Yes i moved to the darkside |
16th Feb, 2009 at 07:22:58am
I had a PiperX sock on the mini in the bad old days and that caused a lot of valve seat pitting on my then fancy 295 head. If you look at the courseness of the foam you can see why! I would only use an oiled cotton gauze from now on or a decent ITG. Plus people shouldn't run the socks that far down the trumpets as it reduces the filtration area by a lot. On 7th Nov, 2008 Nic said:
16th Feb, 2009 at 12:55:51pm
Some one previously posted a link to another forum where some one wondered why his engine injested the fronts off his filters, just cant find it On 26th Oct, 2004 TurboDave16v said:
16th Feb, 2009 at 01:05:25pm
The filters on that are:
16th Feb, 2009 at 01:12:00pm
i used to have itg filtersocks on my fiesta supersport, they worked a treat Crystal Sound Audio said:
16th Feb, 2009 at 01:13:14pm
I have never run anything but a piperX filter. Fine for me. http://www.twin-turbo.co.uk
16th Feb, 2009 at 01:24:44pm
On 16th Feb, 2009 Jay#2 said:
I had a PiperX sock on the mini in the bad old days and that caused a lot of valve seat pitting on my then fancy 295 head. If you look at the courseness of the foam you can see why! I would only use an oiled cotton gauze from now on or a decent ITG. Plus people shouldn't run the socks that far down the trumpets as it reduces the filtration area by a lot. Can an air filter really cause this? I'd have thought that grit would cause bore wear but not valve seat pitting, this is more likely owing to fuel/fueling issues. As Ben says we've only ever used Piper X and had no problems. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
16th Feb, 2009 at 02:15:51pm
Perhaps, but it coincided with me changing over to the sock filter. On 7th Nov, 2008 Nic said:
16th Feb, 2009 at 03:02:39pm
I run a Piper Cross filter on my Metro, it is one you would normally use on the Weber/Dellorto 45 set up.
16th Feb, 2009 at 03:08:34pm
Shocking!! I though one was going to get sucked in haha. |
16th Feb, 2009 at 03:35:15pm
The owner has since burned and cast their ashes to the wind On 26th Oct, 2004 TurboDave16v said:
16th Feb, 2009 at 04:31:53pm
On 16th Feb, 2009 Sprocket said:
Some one previously posted a link to another forum where some one wondered why his engine injested the fronts off his filters, just cant find it ![]() I remember that! They were in his manifold somewhere! On 7th Nov, 2008 Nic said:
25th Feb, 2009 at 02:33:28pm
Custom built composite box moulded around the passenger head light bowl, K&N cylindrical filter drawing air in where the louvre duct attached to the front panel. There is always away! Own the day
