| Home > Help Needed / General Tech Chat > Runs extreme lean on boost, new install... Pitot tube vs. Restrictor | |||||||
8 Posts Member #: 5270 Junior Member Finland |
16th Feb, 2009 at 05:03:14am
Edited by MikaJ on 16th Mar, 2009. |
16th Feb, 2009 at 06:53:45am
sounds liek a problem with your fuel pressure regulator! Fuel pressure needs to rise with the boost not stay at a set level.
16th Feb, 2009 at 07:36:24am
I know that my fuel side is not how it should be on turbo applications, it is fixed 7psi, no regulator to increase it with boost pressure. But I'am running only 3psi boost, so it should work fine (4psi over maximum boost). I have pressure gauges installed on both boost+fuel, and they are fine during drive.
Edited by MikaJ on 16th Feb, 2009. |
16th Feb, 2009 at 01:01:34pm
On 16th Feb, 2009 MikaJ said:
Inlet and plenum is home made and carb is HIF44 There is a restrictor ring built into the Leyland MG plenum. This creates a slight pressure difference generating a pump effect pushing more fuel out of the jet. Have you recreated this restrictor? On 26th Oct, 2004 TurboDave16v said:
16th Feb, 2009 at 01:06:44pm
I know that my fuel side is not how it should be on turbo applications, it is fixed 7psi, no regulator to increase it with boost pressure. But I'am running only 3psi boost, so it should work fine (4psi over maximum boost). I have pressure gauges installed on both boost+fuel, and they are fine during drive. You need a regulator to maintain a constant diferential pressure between the carb and manifold. You have 7 psi at idle/low load and this then drops to 4 psi on boost. Hence the engine leans off under boost. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
16th Feb, 2009 at 01:17:59pm
I think you're all missing the point. The fuel pressure is largley irrelavent, all that it does is allow fuel to enter the float bowl when on boost, it dosen't pressurise it.
Edited by wil_h on 16th Feb, 2009. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
16th Feb, 2009 at 01:58:02pm
Only point is with fuel pressure, is that it is always over air pressure what is in fuel chamber. There is no need pressure regulator on low boost applications, if needle valve can handle enough fuel pressure. On my case, 8psi fuel pressure did not create leak. Example that 4psi fuel pressure on boost is well enough, atleast for me. Pressure differential is only important in fuel injection systems (well not even in there if that is taken care in injection program).
16th Feb, 2009 at 02:07:16pm
How is your float bowl being pressurised at the moment? Does it have a pressurising feed from the turbo? Edited by wil_h on 16th Feb, 2009. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
16th Feb, 2009 at 02:49:06pm
Float bowl is now pressured straight from plenum, so turbo pressure is routed there. |
16th Feb, 2009 at 02:53:21pm
So that makes sense then, the pressure over the jet is the same as the fuel pressure, meaning no fuel will be drawn under boost.
16th Feb, 2009 at 03:22:56pm
Its not just the fuel here, the SU carb needs a differential pressure above and below the piston and the restrictor provides that.. The restriction causes a slightly higher pressure in the plenum than in the carb throat, this higher pressure is fed to the float bowl to ensure fuel can flow into the carb (no pressure difference, no fuel-- thats why you lean out) and underneath the piston to lift it, It even scales the differential according to how much boost. Without it the carb can not work once the engine comes under any boost at all,
Edited by Turbo Tel on 16th Feb, 2009. website:- http://www.terryhunt.co.uk
16th Feb, 2009 at 07:05:31pm
Well I trusted that venturi effect would work with overpressure same way than naturally aspirated. But now when I try to work it out in my head, makes reason that it does not work so well. With more progressive needle/jet combination it might work, but tuning might be nightmare. At this time feels stupid, not to realise this first place. Naturally SU cant measure air mass, with overpressure volume flow with WOT will be the same (well not really, but in small scale), but more air will travel trough it and it feeds same amount of fuel.
17th Feb, 2009 at 08:03:09am
Would one of these fit?
17th Feb, 2009 at 09:53:00am
then from scratch, I would try a pitot tube, that's waht you need |
17th Feb, 2009 at 05:56:41pm
Ok, I don't know that do you fab have some experience about pitot tube for this kind of issue. But it sounded so crazy and in theory it mighted be working solution, that I decided to make one more try before swapping to EFI.
17th Feb, 2009 at 08:28:20pm
try to use this one but inclined 45° in airflow with no bends, not 90° , and try it with first needle,then start to enlarge tube ID, it should point you near balls, then if needed file a little more your needle. |
15th Mar, 2009 at 10:20:46am
Little update. There was some strange problem in first SU carburator itself in first test with Pitot tube. Also choke was leaking on boost, so I decided to remodify my new SU so it could be run with Pitot tube modification (basically back to original).
15th Mar, 2009 at 12:34:47pm
I dont get at all how this works.
16th Mar, 2009 at 08:32:19am
When air flow impacts pitot tube, it generates more pressure inside pitot tube. So example when you have 1bar boost, inside pitot tube there is 1,2bar boost. Pitot tube is routed to SU fuel chamber and forces fuel out of fuel jet.
16th Mar, 2009 at 05:20:53pm
impeccable!
![]() 4637 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
16th Mar, 2009 at 10:07:12pm
So where is the pitot positioned, & how is it connected to the float bowl ? Any pictures ? |
16th Mar, 2009 at 10:58:17pm
On 16th Mar, 2009 Turbo Phil said:
So where is the pitot positioned, & how is it connected to the float bowl ? Any pictures ? Pics are 6 posts up ^^^^ It's a very cute solution - pressure in the centre of flow being higher than wall/edge of flow (ie, the jet) - but something you wouldn't immedaiately think of in this situation. Schrödinger's cat - so which one am I ??? |
16th Mar, 2009 at 11:09:20pm
Oh yeah ! Bugger. Lol. Must be half asleep. :) |
![]() 6753 Posts Member #: 828 Post Whore uranus |
17th Mar, 2009 at 08:52:08am
i put mine in front of the intercooler ,so i got more pressure the higher the revs. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
38 Posts Member #: 11095 Member mold north wales |
4th Mar, 2017 at 02:14:12pm
Hi Wil
