Home > Help Needed / General Tech Chat > another CR question
jwb_moto
Member #: 5170
Bourne
My engine is a boggo 1275cc late carb model fitted with electronic ignition (june 1994 - so a very late carb model) what is the compression ratio likely to be?
Ive been offered a head that has chambers which are 22cc each
would this be suitable for a turbo conversion?
My sister looks like me but with long hair! so save that one for your wank bank i dare you!...
SEARCH BUTTON :)
jwb_moto
Member #: 5170
Bourne
cheers paul great little write up there matey
it is likley to be 9.75:1 ........ not too far off the mark there,
if you are considering turboing it with those pistons in, you will have to increase the CCs in the combustion chambers to 28ccs this will give you a cr of around 8.5:1 this coupled togeather with a good intercooler and 10 psi of boost will give you a shade over 110 bhp
thats if the rest of the engine internals are up to it,
i doubt it as it may well have done starship miles (ie) its not clapped out to start with ................this is only a guide for you .... hope this helps
jwb_moto
Member #: 5170
Bourne
The engine is spot on as it had only covered 16.5k miles when i bought the mini, it had been in storage for 13 years. It even still has all the stickers on the HT leads, stickers on the Aux fan etc
well the clutch and drop gears will fail over that boost
there are many mods to make to an engine to make sure it lives under high boost conditions , thats why i would not advise to go beyond this level
if you need the ccs droping in the head give me a PM
