| Home > Help Needed / General Tech Chat > centre speedo wiring | |||||||
298 Posts Member #: 1357 Senior Member telford,shropshire |
19th Feb, 2009 at 12:06:09pm
hi guys i received my new short loom today to convert from the 3 clocks to the single centre speedo. on the loom there is 5 push in plastic bulb holders,and 2 different type holders.
'always keep a spare shot for a stray bird' |
![]() 87 Posts Member #: 3104 Advanced Member Glasgow |
19th Feb, 2009 at 01:10:07pm
Two of the bulb holders will be for the panel lights, if my memory serves me right these should be red with a white trace, one will be for the ignition/battery charge light which should have two wires white and a brown/yellow trace, one will be for the high beam warning which should be blue with a white trace and the final one should be for the oil pressure warning lamp with should be two wires white/brown trace and white. The sixth hole you can see on the speedo is from long ago when a warning lamp was fitted for a blocked filter on the old Purolater (sp?) cartridge element filters (not spin on).
14.914 sec 1/4 mile @ 91.38mph, NA 1293cc on 1.1/2" SU's (all steel and glass shell) |
19th Feb, 2009 at 01:18:01pm
thats brilliant thanks Keith big help. 'always keep a spare shot for a stray bird' |
19th Feb, 2009 at 01:36:57pm
right i have checked the loom that i have and can only match 2 of the plugs that you have mentioned. blue/white trace and brown/yellow trace.
19th Feb, 2009 at 01:53:17pm
On 19th Feb, 2009 fordimus maximus said:
right i have checked the loom that i have and can only match 2 of the plugs that you have mentioned. blue/white trace and brown/yellow trace. i noticed you did not mention the indicators either? 2 of the plugs have the same colour coded wires red/dark green trace, so these will be the back light? i then have one with blue/white trace and black, one with brown/yellow trace and white and another with green/white trace with green/red trace. i brought the loom from minispares so i assume these are the standard colours? Right, I'm thinking too far back here, I'm used to Mk1 where the indicator light is on the end of the stalk! Blue/white trace and black - High Beam warning Brown/yellow trace and white - Ignition/ charge warning light Red/dark green trace - Panel Lights x 2 Green/White trace + Green/Red trace - Indicators You can always plug everything in, turn it all on and see what lights up when and what flashes! Keith Edited after I checked a wiring diagram - should know better than to trust my memory! Edited by Keith Timpson on 19th Feb, 2009. 14.914 sec 1/4 mile @ 91.38mph, NA 1293cc on 1.1/2" SU's (all steel and glass shell) |
19th Feb, 2009 at 04:23:52pm
thanks, still leaves me short a plug tho? 6 holes 5 plugs?
19th Feb, 2009 at 04:48:18pm
Just having a look now... |
19th Feb, 2009 at 05:00:01pm
Is it because the extra hole you have is for mechanical oil pressure which doesnt use a bulb? |
19th Feb, 2009 at 05:10:08pm
not sure but i dnt think so, on the back it has 4 raised pots, these being 2 for indicators,one for h/b and other for ign. Then it has 2 holes flush to the body which i assume are the holes to illuminate the face. 'always keep a spare shot for a stray bird' |
19th Feb, 2009 at 05:20:41pm
One is for the indicators (G/W&R/G) the R/B&B x2 is for lighting up the speedo. The speedo should only have one hole for indicators unless it's early, usually it's taped off i think. |
19th Feb, 2009 at 05:26:49pm
definitely has 2 for indicators.1 either side. my clock is the 90mph with the 4 lights towards the bottom if that helps, dnt know the year.
19th Feb, 2009 at 05:35:35pm
Is there a rubber cap over the pot at the top? As you look at the lights the one at 4 o clock is for oil pressure (not used) and the one at 8 o clock is also unused, leaving H/B, IGN and indicators at the top. |
19th Feb, 2009 at 09:09:12pm
ah right i thought that these were for the indicators! makes sense now if that is the case.
Edited by fordimus maximus on 19th Feb, 2009. 'always keep a spare shot for a stray bird' |
20th Feb, 2009 at 09:07:00am
Yes the indicator one goes at the very top of the speedo. The wires are for left and right hence only one bulb holder. |
