Home > Help Needed / General Tech Chat > Thermostat housing
Carl S
Member #: 1761
Stalker
One of the bolt holes for the thermostat housing seems to have become thread bare as the bolt is just spinning around in the hole (god knows how it got like that).
Is it worth helicoiling, or changing the head for another? It's a standard 998 engine and head.
Cheers guys.
you get a head for £20. not sure how much a helicoil will cost
graemec
Member #: 1424
Carnforth, Lancs
Helicopil kit would be similar. Difference is you wil be able to do about 10 repairs with a kit and also not have to change the head gasket, reset the rockers etc etc etc.
Helicoil it, won't take long and can be done with the head in place. If you change the head you have to consider the cost of the gaskets,oil etc.. if you keep your head, at least you know the history of the head you're using. *wink*
Timeserts are another option...similar to helicoils.
PaulH
Member #: 2340
Dublin Ireland
Timeserts never use helicoils again there the muts nuts
On 17th Feb, 2009 Rob H said:
Pottsy
Member #: 843
Stoke-on-Trent. Duck.
All you effectively need to do is give the stud a decent enough 'home' to be sure the 'stat housing seals. It's not like it's structurally holding things together, Helicoils should be fine I reckon.
To be hones, I don't understand which one you favour here.
I like Helicoils..
Carl S
Member #: 1761
Stalker
With helicoils, will I be alright for clearance from galleries and such?
tadge44
Member #: 2500
Buckinghamshire
All good ideas, but a quick and dirty fix is to drill and tap a size up and drill out the housing to take the bigger stud/bolt(or make a stepped stud)
