| Home > Help Needed / General Tech Chat > Turbo Core Balancing | |||||||
8 Posts Member #: 2790 Junior Member |
20th Feb, 2009 at 06:21:50pm
Hi just a quickie , ive rebuilt a std t3 metro spec turbo with a new bearing core, bearings, thrust washer etc, piston rings and a new turbine shaft and its come to the point of needing balanced, ive rung Turboactive up today from work and they quoted me £60-100 to have my core balanced as a unit, is this the going rate? also does anyone know of any other companys i could try/use and what they would charge for the above ? Any help would be great :)
20th Feb, 2009 at 08:16:08pm
Turbo dynamics On 17th Feb, 2009 Rob H said:
21st Feb, 2009 at 07:21:52pm
Cheers, ive sent a message to enquire :) Anymore ?? |
16 Posts Member #: 2838 Member |
22nd Jun, 2009 at 11:17:34pm
John. Did you get any further with finding someone to balance the turbo. I need to get my unit rebalanced after a rebuild.
23rd Jun, 2009 at 02:45:15pm
Turbo Dynamics wont do it unless they rebuild it themselves.
Edited by Kean on 23rd Jun, 2009. |
