Home > Help Needed / General Tech Chat > Different ways to mount seats?
jakelloyd99
Member #: 5310
Oxford/Hertford
Im currently using the tilt and slide cobra subframes but the seating position is too laid back and i have to compromise between a comfortable pedal position and gear stick reach. I want to mount my seat more up right and lower down, can anyone suggest ways to mount the seat?
Cheers Jake
Which seats have you got?
i had same problems i have long legs but short arms lol, i had to (or just did)cut out the crossmember there i a couple of pics in my build thread the link in my sig
jakelloyd99
Member #: 5310
Oxford/Hertford
Ive got cobra clubmans a the moment but was considering sparco sprints or somthing similar with more support.
ok ill have a look, i while back i read about someone mking lower/lighter cross members. does any one know any more about these?
I don't see why you couldn't lower the box section if realy necessary.
MarkGTT
Member #: 1194
Shropshire.
Mine are mounted behind the cross member, is that an option for you? or do you still have rear seats?
t3gav
Member #: 229
Gavin@minispares.com
kent
If you get the sparco's etc they will be side mount anyway so you can pretty much mount them wherever you like.
jakelloyd99
Member #: 5310
Oxford/Hertford
Yeah, theses no restriction on where they go, theres nothing else in there.
How is it for reaching the wheel, gear stick with them mounted there? Or is it ok because of the more up-right possition?
MarkGTT
Member #: 1194
Shropshire.
i find the driving position much better.. i guess it depends on your height and reach.
jakelloyd99
Member #: 5310
Oxford/Hertford
Cheers for that, ill offer the seat up and see what works
