Home > Help Needed / General Tech Chat > Megajolt Cable
jonb_5
Member #: 3193
Torbay, Devon
Need an RJ11 cable for my megajolt, anyone know where i can get one, to serial or usb???
Thanks
JOn
maplin
this baby works on mine
http://www.pcwb.co.uk/catalogue/item/A0385043
Carl S
Member #: 1761
Stalker
you can buy them from the megajolt shop Jon.
gr4h4m, that would only work with a v3 or previous edition MJLJ controller. The V4 uses an RJ11 connector instead of the Serial (RS232) connector.
Edited by Carl S on 23rd Feb, 2009.
jonb_5
Member #: 3193
Torbay, Devon
Does anyone see why this would not work?
ebay item number: 400032526527
Thanks
Jon
opps mis-read it... was talking about the converter for USB only laptops
Re. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=400032526527
Maybe, maybe not - as it's designed for connecting to a modem (??? that's what it implies) it's unclear if it's doing a normal serial conversion and you certainly don't know what order the four wires are connected to the RJ11.
My TechEdge wideband stuff is the same issue (uses RJ11s) and the wiring connections are weird - but I don't know if "weird" is standard or if MJ uses a different configuration.
I do remember that somewhere on the autosport web site and/or forum they have posted the required wiring so you can use a spare telephone cable to make your own adaptor to a serial plug.
EDIT - spelling
Edited by Rod S on 25th Feb, 2009.
jonb_5
Member #: 3193
Torbay, Devon
Could i not just use an rj11 cable and put in the port next to the network port on my laptop??
Thanks
Jon
no!, that port is the modem!
The serial comunications uses the RS232 protocol, it iether needs to be connected to a USB port with the apropriate adapter or the DSUB9 serial port (com1)
As I've already said, if your laptop has a real serial port (RS232) you just need an old phone cable and a serial plug to make your own cable.
here is the link to save you searching....
http://www.autosportlabs.net/MJLJ_V4_Opera...de#Serial_Cable
Look at section 2.1 if the link doesn't jump straight there.
If you only have USB, still make the cable, then plug it into a serial/USB convertor.
Edited by Rod S on 2nd Mar, 2009.
miniboo
Member #: 2253
Las Vegas, Brit in the States
I have loads of serial cables and rj11 connectors at work. perhaps i should a knock a couple up?
