| Home > Help Needed / General Tech Chat > crank shaft timing keyway | |||||||
492 Posts Member #: 3684 Senior Member wisborough green west sussex |
26th Feb, 2009 at 04:29:18pm
i am in the process of putting my timing gear onto my new build and i have two crank keyways to try, one from my standard metro turbo engine and one from a old 1380 engine but neither of these will fit my new crank they are both the same size and both too small for my crank they just fall out.Are there different size keyways?.
26th Feb, 2009 at 04:46:08pm
I am pretty sure (99.9) they are all the same, 998 to 1275.
26th Feb, 2009 at 04:50:37pm
thats what i was thinking, the crank is freshly machined though so dont think it would be that worn? |
26th Feb, 2009 at 07:20:57pm
998 and 1275 of all flavours use exactly the same key. |
26th Feb, 2009 at 07:47:31pm
Offset keyways are for camshafts though. They will fit in the cam slot On 12th Nov, 2009 Paul S said:
Gary's description is best |
1st Mar, 2009 at 12:32:40pm
right i have tried four different keys now one being new and they are still not going in tight! does anyone have any sugestions of what i can do? do i get a key machined to fit in the keyway and the timing gear? or locktight or something PLEASE HELP |
1st Mar, 2009 at 01:16:26pm
What do you mean by "the crank is freshly machined" ???
1st Mar, 2009 at 01:19:43pm
thanks for reply, what i mean is its fresh from morspeed its had work done to it but i would have thought he would have checked the keyway for damage before doing the work? |
1st Mar, 2009 at 01:50:41pm
On 1st Mar, 2009 turbo22 said:
thanks for reply, what i mean is its fresh from morspeed its had work done to it but i would have thought he would have checked the keyway for damage before doing the work? Apparently not..... Was it your own crank that they worked or was it sold as an "exchange" so from an unknown source ??? Either way, it will have been worn before they touched it as that area wouldn't have been worked. Whether they should have checked it is debatable - it's not a place that normally wears unless the pulley retaining bolt hasn't been tight enough in the past. Try talking to them and see what they say - if it was an exchange, it should be "fit for purpose" but if it was yours, then it was 99.9% certain to have been like that when you sent it. If it was an exchange you could argue it wasn't "fit for purpose". Personally, unless it's really bad, I would use loctite, the highest grade, studlock 270 (now sometimes called 2701) and make sure the sprocket is rotated anticlockwise to the full extent of the slack in the keyway before doing up the bolt and letting it cure. NOT a real solution, just a bodge - to do it properly, a machine shop could recut the keyslot to a new defined size and either recut the sprocket to match or provide a stepped key. Or cut a new keyway 180 degrees out and re-mark the sprocket "dot" 180 degrees out..... Schrödinger's cat - so which one am I ??? |
1st Mar, 2009 at 03:16:57pm
i got the crank in an engine kit from someone else who never built the engine, i think it was his crank before he got it machined at morspeed,i think ill go for the stepped keyway option as a bodge is not an option
1st Mar, 2009 at 09:24:54pm
Anyway, when the pulley is torqued up, there will be noe "force" on the keyway. If it's so tight that you can time the camshaft up decently you should be OK. On 13th Jul, 2012 Ben H said:
2nd Mar, 2009 at 08:30:11am
so vegard are you saying if i lock tight it should be enough because the pullly stops it from moving when tight anyway? |
2nd Mar, 2009 at 08:58:07am
I think that's what I'm saying in a slightly more eloqent way On 13th Jul, 2012 Ben H said:
2nd Mar, 2009 at 03:58:41pm
I would make a new key up that is slightly thicker and just open the keyway up in the pulley to suit. If you have any play between the key and keyway over time the slot will become more of a 'V' and cause no end of trouble. Do it right once and forget about it. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
2nd Mar, 2009 at 04:17:01pm
yep agreed and have it booked in for tommorrow |
2nd Mar, 2009 at 05:23:17pm
On 2nd Mar, 2009 matty said:
I would make a new key up that is slightly thicker and just open the keyway up in the pulley to suit. If you have any play between the key and keyway over time the slot will become more of a 'V' and cause no end of trouble. Do it right once and forget about it. ![]() What on earth would cause it to wear? On 13th Jul, 2012 Ben H said:
2nd Mar, 2009 at 05:44:33pm
id just tack weld it in place, and use a vernier "Turbo's make torque, and torque makes fun"
2nd Mar, 2009 at 07:21:25pm
I,m with Matty on this. My training was that all keys should be a snug fit in both components or fretting can occur.I understand the point about extra clamping pressure from the pulley bolt but would still feel happier with a good fitting key.Its a more elegant solution,anyway. |
2nd Mar, 2009 at 07:43:46pm
I would make a new key up that is slightly thicker and just open the keyway up in the pulley to suit. If you have any play between the key and keyway over time the slot will become more of a 'V' and cause no end of trouble. Do it right once and forget about it. ![]() What on earth would cause it to wear? The key will tend to rock ever so slightly in the keyway causing it to wear the edges of the key/keyway as the wear increases so does the rocking action. Seen it far too many times on machinery at work.
2nd Mar, 2009 at 08:35:27pm
but is that machinery where the keyway provides the drive? in this application the drive (or transfer of torque) comes from the tight bolt, the keyway is simply there for location purpouses. if the bolt is correctly torqued, the woodruf key will never see any forces placed upon it. turbo 16v k-series 11.9@118.9 :)
2nd Mar, 2009 at 08:43:56pm
Ah yeah I see what you mean! It should be ok in that case. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
2nd Mar, 2009 at 08:48:16pm
It's all down to how bad the wear (looseness of the key) actually is....
