Home > Help Needed / General Tech Chat > starter woes
bigmini998
Member #: 2830
Costa del Northern Ireland :)
Ive just rebuilt my 998 turbo. and replaced the crank with a low milage automatic one.
now with the engine all built up and in the car i fitted the starter but the pinion rubs the flywheel *frown*
so my thoughts are that my steel flywheel has been lapped to many times and now sits further up the taper of the crank. (i have lapped this flywheel 3 times)
would any of you think it would be ok to either make up a spacer for the starter or storten the pinion to clear the flywheel??
cheers guys
That mini is determined to Kill me!!!!
hario
Member #: 2885
Spacer or washers under the starter bolts sounds easiest.
I have to use spacers for mine to clear (about 1.5mm). Never had a problem using them.
