Home > Wanted > A screw (for a weber) 05.04.09 - Still required
I have got the bottom of why the mini is running like a bag of shite, a little screw that fits just before the manifold has fallen out.
Does anyone have a spare screw lying about?
Here is what it looks like and where it goes.
Thanks very much
James
Edited by minimole23 on 5th Apr, 2009.
scooperman
Member #: 2234
Palm Beach Gardens, Florida
Weber part number is 61015.009, if that is any help.
lockfast
Member #: 2775
Aberdeen
I think I might have! I will check tommorow for you. I have a scrap 40 somewhere I am sure all the brass screws are still in it.
Thanks for that
Hmmm weberyyy
On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy
Anton
Member #: 764
Staffordshire
i will have one.. i will dig it out later for ya
Ahh, brilliant*happy*
Anton
Member #: 764
Staffordshire
i have two, one that is hollow and has a rubber o ring the other is solid with no o ring... which one do you need?
Anton
Member #: 764
Staffordshire
ahh re-looking at the photo i think you need the shorter non o ringed version
scooperman
Member #: 2234
the hollow one with the o-ring fits over the accelerator pump jet, further back from the mounting flange. The solid one is the cover for the progression holes port, that is the one he needs.
After a mini company has sent me the wrong screw, this is still required. If I remember correctly it is about 7mm in diameter, not 8. something.
James
PaulH
Member #: 2340
Dublin Ireland
PM me your address and ill send you one :)
On 17th Feb, 2009 Rob H said:
this guy will definately have what you need bud
http://stores.ebay.co.uk/FAST-ROAD-CARS
Not sure if he comes on here much now, but if you can get hold of "danboy" on here I am sure he will be able to sort you out, he rebuilds webers and knows his stuff.
Anton
Member #: 764
Staffordshire
did you not get the one i sent out?
Thanks very much for that, but it must have got lost in the post. Bloody royal mail. I just assumed there had been a problem at your end so didn't want to press the matter.
danboy hasnt checked his pm's in nearly a year tom, do you know what hes up to?
