Home > Help Needed / General Tech Chat > clutch Prob
Zeemax Power
Member #: 393
Oulton Park
Happened about 5:30 tonight so haven't had a look yet but was after a bit of help.
Basicly was back out of my drive. i heard a grinding noise when i turned the car. Put the clutch down and the car stalled, so knocked out of gear, and when put foot on the clutch again it went so far then solid, and wouldn't go into gear.
Whats first port of call and whats most likely to be prob?:$ cheers
http://www.Zeemax.com
ministef1
Member #: 1791
Cranleigh, surrey
clutch release bearing or ball on the end of the clutch arm? take the wok of and have a look.
"Cars are a lifetime of pain"
Most likely as above ^^^^^
For a very quick check, pull the boot (dust cover) off the end of the slave cylinder and see if the piston is now right up against the circlip (hence it can't move anymore so the pedal is solid).
If it is at the end of its travel it pretty much confirms the above....
hope thats all it is for you
dont mean to sound negative but the flywheel may have come loose or the plate broken up
an hours work will reveal all
