| Home > General Chat > anybody out there work for the electricity board installation dept ? | ||||||
3rd Mar, 2009 at 10:21:19pm
ive got an interesting situation here ,goes like this .
4th Mar, 2009 at 08:25:29am
I'm not going to be any help, but I don't fully understand. Surely if the electricty is cut off it will get cut off at the substation (as that's what has not been paid), they won't come to each building, as it's not their meteres.
4th Mar, 2009 at 09:40:32am
I'm involved with a site up here where my client has 2 sub-stations/transformers on site and has installed sub-metering for the sub-divided units.
4th Mar, 2009 at 09:53:20am
On 4th Mar, 2009 wil_h said:
I'm not going to be any help, but I don't fully understand. Surely if the electricty is cut off it will get cut off at the substation (as that's what has not been paid), they won't come to each building, as it's not their meteres. So just changing your meter won't make any difference to your predicament. I must have this wrong, please explain. the idea wil was to have seb take out the sub stn meter ,on site ,and put a direct link in there ,then put seb meters on each house and each unit ,so charging each person directly ,as in a normal site . the transformer is on the telegraph pole outside the site ,then feeds the normal 3 ph to the sub station ,which is a building on site with a big genny and so on in it ,, the site was a gas attack proof secure research establishment . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
4th Mar, 2009 at 10:10:35am
have a word with your local MP
4th Mar, 2009 at 03:30:54pm
I'm not going to be any help, but I don't fully understand. Surely if the electricty is cut off it will get cut off at the substation (as that's what has not been paid), they won't come to each building, as it's not their meteres. So just changing your meter won't make any difference to your predicament. I must have this wrong, please explain. the idea wil was to have seb take out the sub stn meter ,on site ,and put a direct link in there ,then put seb meters on each house and each unit ,so charging each person directly ,as in a normal site . the transformer is on the telegraph pole outside the site ,then feeds the normal 3 ph to the sub station ,which is a building on site with a big genny and so on in it ,, the site was a gas attack proof secure research establishment . Problem is that all of the equipment from the main substation to your own front door is the property of the landowner, so they cant just remove the sub meter and link it through, it would still be essentially supplied via his distribution system that he is not paying the bill for. They will have to install a fresh incomer from the road straight to your property, totally bypassing any of the previous distribution system. However, I do not think that this is your fault. Someway or another they need to work it out between themselves who is going to pay for the works to be carried out, otherwise they are going to loose all of the custom if they cut off the main supply. |
4th Mar, 2009 at 03:57:35pm
On 4th Mar, 2009 BENROSS said:
have a word with your local MP Crystal Sound Audio said:
4th Mar, 2009 at 04:53:28pm
It seems that because the main supply went to what you call the substation on his site, because that isn't the area board's substation, you are not buying your electricity from the area board but from the owner of the "substation" - even from their diesel generator if it ever runs......
4th Mar, 2009 at 06:49:32pm
thank you very much to everyone for chipping in on this .
4th Mar, 2009 at 06:58:13pm
swapping over meters seems such obvious common sense ! I see where you're coming from, but swapping meters doesn't stop the power being routed through cabling and switchgear owned by someone else, with no obligation to maintain it, keep it safe, etc. I suspect that is why SEB just say run a new cable of their own. H&S is out of hand at the moment. EDIT - typo Edited by Rod S on 4th Mar, 2009. Schrödinger's cat - so which one am I ??? |
