| Home > Help Needed / General Tech Chat > Play in Steering Rack | |||||||
4th Mar, 2009 at 03:52:57pm
I have a slight amount of play in the Passenger side of my rack. I can feel it moving a couple of mm. Can i take this slack up by taking the circlip out and removing the arm then popping a washer or something in the end?
4th Mar, 2009 at 04:14:26pm
mike get a new rack from minispares i can pick you one up there around £45 ish.................. let me know
4th Mar, 2009 at 04:33:12pm
There's salvaging it then? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
4th Mar, 2009 at 04:33:37pm
There's no salvaging it then? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
4th Mar, 2009 at 05:21:03pm
On 4th Mar, 2009 MikeRace said: yes, mike you can take up the slack as far as i know, peel boot back, you need to screw in the cup that holds the inner ball of the track rods, i think you will have to prize out the loking machanism that stops it coming loose, its part of said cup punched in to groove on rack.
There's no salvaging it then? carl |
4th Mar, 2009 at 10:33:32pm
Sweet, nice 1 carl. I'll check it out at weekend, thanks for the tube by the way! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
