Home > General Chat > My latest hair brained Idea
PaulH
Member #: 2340
Dublin Ireland
to Quote The Fentonator " pictures speeke a 1000 words
Lots more Pic on the way when the camra starts to talk to me again (they realy dont like being droped.......down the stairs..........Again)
On 17th Feb, 2009 Rob H said:
evolotion
Member #: 83
Glasgow, Scotland
hope your slotting a diff and some bespoke 4wd system in there :)
Denis O'Brien.
hell Paul looks interesting!
AWDmoke
Member #: 713
Western Australia
Another twinnie in the making?
On 24th Dec, 2008 Nic said:
rear wheel steer? :)
mmm... interesting...
PaulH
Member #: 2340
Dublin Ireland
Thanks lads been thinking of doing it for a long time I had just finished puting in a flat boot floor only to cut it up and do this :).
ho and Not a twinne
or 4WD
but should corner like a bitch I hope. The wheel base is about 5 inch longer and I am able to now run the car just under 4 inch of the ground which should be intresting for this years racing I hope.
hughesmarkie
Member #: 1197
Dublin Ireland
Paul you truely are a legend *wink* ha ha ha good work mate!
PaulH
Member #: 2340
Dublin Ireland
Ho an I can now run any standard four pot all caliper, KAD alloy hubs, 7 inch disks and the sub-frame in is new form with standard disks hubs and calipers is about 30% lighter than a standard rear sub-frame so with the right alloy components it should be easy to get it to 60% lighter :) someone needed to give it a go.
Edited by PaulH on 5th Mar, 2009.
nice plan, you will need to make a special short hi-lo key todo the corner weights
PaulH
Member #: 2340
Dublin Ireland
Ya Jim I have used some standard M10 bolts in the Pic to hold the tower in place for mock up, but in the final setup I will have a custome Tower bolt with the Standard hole trough the centre I have a set of ripspeed hi-lo's with the alen adjustment bit in them so should be a doddle to adjust the corner weights all around rather than having to have the car on a 4 post ramp. I have always made my own Keys anyway so should be a big problam I have also cut a small slot in the twoer to alow be get a spanner on the locking nut.
Doesn't the top arm foul the inner arch?
PaulH
Member #: 2340
Dublin Ireland
It sure DID Will so now ther is a new inner arch what I find cool was the shock now lines up with the orignal shock mount :)
uhmmm. i need pics of the underneath. looks like an interesting idea.
How are you locking the steering bit of the hubs?
I imagine hes using the trackrod end and a bar fixed to the subframe.
This would give him toe in toe out adjustability!
PaulH
Member #: 2340
Dublin Ireland
yup thats it mike a simple turn buckle type adjuster giving very fast simple Toe adjustment and with an adjustable botom arm giving me very simple camber ajustment. James more pic to follow when that is the photo box comes back from being taped back together
and a camber gain on the back in cornering mode, and discs.
ooof!!
nice job paul ,well done .
is that the standard subframe width Paul?
PaulH
Member #: 2340
Dublin Ireland
Thanks Robert,
I keep thinking Im missing somthing it seems so right and tbh not all that hard to fit so far I have spent about 5 hours on it and 3 of that was cuting down a sub-frame It all fits so well into the back. there is a bit of engineering to get it right but not beyond anyone with a bit of welding skill and a front subbe *wink*
PaulH
Member #: 2340
Dublin Ireland
yup 8-)
codd_coupe
Member #: 1772
Leicestersheershire
This is how we do it on the GTM rear end. There is a newer design now though, which gets rid of the bump steer.
Tim Rowe
"Is est totus perfectus per fumi quod speculum"
GTM Coupe Turbo
PaulH
Member #: 2340
Dublin Ireland
Do you run the botom tie bar Tim on the GTM's ?
codd_coupe
Member #: 1772
Leicestersheershire
It is exactly the same as a mini front end, but with the steering locked off as show. The problem is the arc of the steering arm doesn't exactly mimic the travel of the hub. Therefore as the wheel rises and lowers the toe of the wheel changes slightly.
You'll need to calculate your spring rate too, as you haven't got the engine weight on it. That is what we do on the front with the Coupe. The low tech approach is to drill some holes in the rubber cones.
Tim Rowe
GTM Coupe Turbo
Why has no-one asked the most important question yet???
Will it have an engine capable of doing wheelies???
Id love a car that will do wheelies, I will have one before I die. It almost makes me wish that I got into beetles instead
