| Home > Help Needed / General Tech Chat > Is this engine spec good enough for a turbo? | |||||||
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
6th Mar, 2009 at 08:20:34pm
Hi all,
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
6th Mar, 2009 at 09:05:21pm
I think you would want a tamer cam than the 276. A good standard cam for turbo use is the Metro NA cam. Also, is your HIF44 a turbo carb or are you planning to convert an NA carb?
Edited by GaryOS on 6th Mar, 2009. On 12th Nov, 2009 Paul S said:
Gary's description is best |
6th Mar, 2009 at 09:35:19pm
the carb is a n/a carb, i didnt realise there was any difference between the two. What will I need to do to convert? Hoping to run around 10-12p.s.i?? Oh ok thanks. I may see how the standard diff holds up as I dont want to remove and strip the engine, but i will have to if it fails lol On 25th Sep, 2009 mini13 said:
6th Mar, 2009 at 09:35:21pm
6th Mar, 2009 at 09:40:40pm
The 21253 pistons aren't really suited for turbo applications. On 13th Jul, 2012 Ben H said:
6th Mar, 2009 at 09:42:31pm
On 6th Mar, 2009 1293 sprite said:
I may see how the standard diff holds up as I dont want to remove and strip the engine, but i will have to if it fails lol From personal experience. when the pin in the standard diff fails, there is a high probability it will punch a hole in the gearbox casing.... And that was on a standard MG Metro engine at 70k miles. For my turbo project the MiniSpares X-pin was first on the list - now to be superceded by the Quaffe (sp?) that Iain has sorted out for us - but I just wouldn't trust a standard pin, especially "used" without even looking at it. Schrödinger's cat - so which one am I ??? |
6th Mar, 2009 at 09:58:01pm
oh ok, thanks.
6th Mar, 2009 at 10:10:44pm
The X-pin diffs aren't cheap, around £160 from memory, plus all the gaskets, tabwashers etc. you will need to do the swap.
6th Mar, 2009 at 10:48:42pm
It already has the uprated straight cut drop gears which are only about 6k miles old, so they should be fine, its just the diff thats the problem On 25th Sep, 2009 mini13 said:
7th Mar, 2009 at 08:44:25am
If going the uprated diff route, you'll also need new planet gearsm new bushes etc. There is really no excuse for not fitting a twin pin. Do it. Don't be cheap on this item. Remember to buy the Minispares one as the Minisport one is shite in comparison.
7th Mar, 2009 at 10:28:10am
as above, but the pistons will peal their tops off at that boost, i would go for omegar 11 cc dish pistons £280 deliverd from med, that togeater with 28cc in the head chambers will give you 8.5:1 CR just right for a saftey margin for detonation, if you want the chambers sorting please give me a PM
7th Mar, 2009 at 10:37:32am
As your head is for a NA engine you may find it's been skimmed to give a desired compression ratio. Whether it will be possible to increase the chamber volume to something suitable, will depend how much has been removed. |
7th Mar, 2009 at 12:15:23pm
thanks for the help. What would you class as low boost? £280 isn't bad for a set of cast pistons really, they would be about that much just for one piston in my brothers car lol. I will probably go that way with it, rather than skimp on important parts and risk failure. It will be a little longer term than i first planned, because of poor apprentice wages. I can probably save a little money at MED by collecting the pistons and paying cash, as he is only about a 20 minute drive from my house. On 25th Sep, 2009 mini13 said:
7th Mar, 2009 at 01:05:05pm
i've been running 21253's for the last 3 years @ 15psi and they're spot on, they've seen 20psi a few times aswell. mine are dished out to 11cc. i'm running 8.7:1cr and it was making around 160 banana's at 15psi.
Edited by Nick on 7th Mar, 2009. On 20th Oct, 2015 Tom Fenton said:
7th Mar, 2009 at 01:20:36pm
oh right thanks. If yours are 11cc and mine are 10cc, there isn't much difference, that extra 1cc could be taken from the chambers?? 8.7:1, 15 p.s.i of boost and 160 bannanas?? That is more power than i would be hopefully runnung, but if the pistons will take that then thats reassuring. I would hopefully be running about 10-12 psi, for about 130-140hp? What CR would i need for that please? On 25th Sep, 2009 mini13 said:
7th Mar, 2009 at 02:18:20pm
On 7th Mar, 2009 Nick said:
iirc nic used to run them aswell before he got all fancy. oui oui hahaha im tempted to sig that |
7th Mar, 2009 at 03:13:37pm
My AE pistons saw about 16-17PSI and I had them in there for about 20k and on strip down couldn't see any problems. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
7th Mar, 2009 at 05:44:59pm
Oh thanks. I had my engine set up at northampton motorsport before, so will probably go back there. I have a smart car intercooler which i have just had a play trying to mount it, but I'm struggling to find somewhere to mount it. The engine seems to sit quite far foreward and wont go between the dizzy and the front panel. I also have a servo on there which is also in the way. Any ideas on that one?
7th Mar, 2009 at 05:54:34pm
I'd be tempted to ditch the dizzy and go megajolt. On 7th Oct, 2010 5haneJ said:
7th Mar, 2009 at 05:59:45pm
yeah, thats what i'm thinking. Is it expensive? I can get hold of ford coil packs through work cheap. On 25th Sep, 2009 mini13 said:
7th Mar, 2009 at 07:51:46pm
I'm in the process of going through it now, got all the bits I need from a scrappy for £25 and the megajolt is about £150. I really need to hurry up and order it.
7th Mar, 2009 at 08:31:14pm
yeah, I think i will do that, but i'll probably have to buy a bottom pulley already machined. On 25th Sep, 2009 mini13 said:
