| Home > General Chat > What do you make of this beam? | ||||||
9th Mar, 2009 at 04:39:02pm
http://cgi.ebay.com/ebaymotors/CLASSIC-MIN...sQ5fAccessories
9th Mar, 2009 at 04:42:48pm
Interesting. a weight would be nice.
9th Mar, 2009 at 04:43:31pm
I like! :) Would be interested to see how much it weighs though? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
9th Mar, 2009 at 04:51:15pm
i like the ARB, its nice and simple. The rest looks a bit heavy, the toe adjustment on the spindles is a bit strange? why not just do it on the other bush, they have done it for camber so surely its just a case of turing the bits around 90deg!
9th Mar, 2009 at 05:00:37pm
Is it me, or does it look like bird sh1t welding on the arms? On 17th Nov, 2014 Tom Fenton said:
9th Mar, 2009 at 05:01:44pm
It does actually Dave! uhmmmm suspect! |
9th Mar, 2009 at 05:08:59pm
On 9th Mar, 2009 slater said:
i like the ARB, its nice and simple. The rest looks a bit heavy, the toe adjustment on the spindles is a bit strange? why not just do it on the other bush, they have done it for camber so surely its just a case of turing the bits around 90deg! I quite like the toe - anything on an eccentric is better than pulling shims apart and doing it that way. It also moves only the piece you want to move - the hub... Like you say; good inspiration. On 17th Nov, 2014 Tom Fenton said:
9th Mar, 2009 at 05:18:22pm
Im not keen on those offset top mounts for the dampers |
9th Mar, 2009 at 05:21:18pm
and where they mount to the arm aswell. they look abit weak to me. |
9th Mar, 2009 at 05:35:51pm
On 9th Mar, 2009 Nic said:
Im not keen on those offset top mounts for the dampers I agree. That's just stupid! On 13th Jul, 2012 Ben H said:
9th Mar, 2009 at 06:03:54pm
£700 and shipping from Georgia a bit pricey? On 5th Sep, 2011 Vegard said:
9th Mar, 2009 at 06:06:48pm
Does anyone else think those brackets will twist before the ARB does anything useful?
9th Mar, 2009 at 06:18:07pm
On 9th Mar, 2009 Scruffy said:
£700 and shipping from Georgia a bit pricey? Yes, the exchange rate now really reduces margins on USA made parts, or makes them unattractive on price. For myself, I don't want to go back to an un-anodised, water-jet cut front plate, but I am making nothing on the prices that I'm selling them for today. It is clear No-one will pay 35 quid (plus shipping) for them, but It is barely worth my effort at 30 quid given the assembly time, packaging time and trips to the post office. Right now, I'm selling inventory. Once that is gone, economics will dictate if I'll make another batch.
9th Mar, 2009 at 06:21:16pm
There must be alot of force on that outer bolt near the stub axle under braking though?
i like the ARB, its nice and simple. The rest looks a bit heavy, the toe adjustment on the spindles is a bit strange? why not just do it on the other bush, they have done it for camber so surely its just a case of turing the bits around 90deg! I quite like the toe - anything on an eccentric is better than pulling shims apart and doing it that way. It also moves only the piece you want to move - the hub... Like you say; good inspiration. On 19th Jan, 2010 wil_h said:
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
9th Mar, 2009 at 06:23:51pm
They are the same guys that do all the Vtec conversion stuff. |
9th Mar, 2009 at 06:24:59pm
On 9th Mar, 2009 Tom Fenton said:
Does anyone else think those brackets will twist before the ARB does anything useful? I looked at them, but wasn't so sure they would if the ARB is in like with the pivot axis of the arms as the majority of the load would be into the deep shear plane of the U sides. Only a small offset however, and then the two sides of the 'u' would parralelogram however. On 17th Nov, 2014 Tom Fenton said:
9th Mar, 2009 at 06:28:01pm
Not really, rear brakes are low effort. Just compare that geometry to front-end geometry (like the section around the holes on the stock tie-bars). Forces are high, but the cars aren't heavy!
On 9th Mar, 2009 Jason G said:
There must be alot of force on that outer bolt near the stub axle under braking though? On 9th Mar, 2009 TurboDave said: On 9th Mar, 2009 slater said:
