| Home > Help Needed / General Tech Chat > clutch and boost | |||||||
9th Mar, 2009 at 08:07:30pm
just wondering what guys are running to what pressure plate and what final drive.
9th Mar, 2009 at 08:27:11pm
Double grey is the easiest solution for you. Or you can make a twin-spring verto, or you can re-mortgage your house ready for when my clutch is done (damn exchange rate) :(
9th Mar, 2009 at 09:24:05pm
I had to fit a double grey. 16+psi & my single grey slipped. |
9th Mar, 2009 at 09:28:33pm
for a road car i personally would steer clear from a double grey from a thrusts point of view, i'm going to give a twin spring verto a whirl. On 28th Aug, 2011 Kean said:
9th Mar, 2009 at 09:59:24pm
I bought Carl's engine which had a single grey and ate the thrusts after no more than 3500 miles.
Edited by theoneeyedlizard on 9th Mar, 2009. In the 13's at last!.. Just |
9th Mar, 2009 at 10:02:54pm
while you have the clutch out did you modd the back plate by removing 1.5mm from the 3 lugs ?
9th Mar, 2009 at 10:09:14pm
Go double grey, it's not that bad on the left leg or the thrusts. I'm suprised a single grey has lasted you this long, as you've got quite a bit of power at the moment.
10th Mar, 2009 at 12:59:24am
Clutch is on my hard drive. Which is being recvovered at a cost of $2500 so far.... On 17th Nov, 2014 Tom Fenton said:
10th Mar, 2009 at 06:49:03am
cheers for response guys will have to check when i remove it soon.
10th Mar, 2009 at 07:54:21am
I was going to ask this question so I may as well ask here if you don't mind? With the clutch assembled I have the straps just touching the lugs on the backplate. So I take it the TD method will give you a bit of a gap there? On 7th Nov, 2008 Nic said:
315 Posts Member #: 3013 Senior Member Epsom Surrey |
10th Mar, 2009 at 09:38:09pm
what about verto clutches?? can you do anything to mod these to get a higher clamping force on the plate!!! |
10th Mar, 2009 at 11:03:30pm
On 9th Mar, 2009 TurboDave said:
Or you can make a twin-spring verto, |
10th Mar, 2009 at 11:32:02pm
hoggy, me and t2clubby both only use 2 straps on ours but after taking the height off the backplate lugs we've had no problems with clutch slip. kean uses the AP rally plate with around 200lb/ft and i used a std minispares "uprated" £16 plate with 170 ft/lb.
Edited by Nick on 10th Mar, 2009. On 20th Oct, 2015 Tom Fenton said:
11th Mar, 2009 at 07:23:11am
cheers for that nic best i give that a bash then i take it it is 60 thou to take of or 1.5mm always looking for them bigger bunches of bannanas |
11th Mar, 2009 at 09:40:37am
What height does the backplate end up at after taking the 60 thou off?
11th Mar, 2009 at 09:53:29am
On 11th Mar, 2009 theoneeyedlizard said:
What height does the backplate end up at after taking the 60 thou off? I want to find out if mine has already been done. That's what I want to tease out, standard I think the straps just touch the horns of the back plate. If you machine them down then there would be a gap. On 7th Nov, 2008 Nic said:
11th Mar, 2009 at 10:05:20am
we'll measure a std one tonight,
11th Mar, 2009 at 10:13:41am
how do you make a twin spring verto?? i tried to search it n cant find anything? |
11th Mar, 2009 at 10:17:41am
search for a thread called thread called clutch thoughts :) On 28th Aug, 2011 Kean said:
11th Mar, 2009 at 10:18:12am
Look at Roberts "Clutch thoughts" thread. Or search RTS (Robert's Twin Spring) Clutch.
Edited by theoneeyedlizard on 11th Mar, 2009. In the 13's at last!.. Just |
11th Mar, 2009 at 11:21:24am
Dave, is your clutch package something like the pics I sent you a couple of years ago ? |
11th Mar, 2009 at 11:56:49am
What height does the backplate end up at after taking the 60 thou off? I want to find out if mine has already been done. That's what I want to tease out, standard I think the straps just touch the horns of the back plate. If you machine them down then there would be a gap. There is now exact figure for this Bolt it all up and measure the damn thing. I've ended up removing WAY more than 60thou on occasion. On 13th Jul, 2012 Ben H said:
11th Mar, 2009 at 01:05:32pm
There's no point machining the lugs if it's not required. You just need to machine enough off to get the diaphragm to sit flat. |
11th Mar, 2009 at 01:21:22pm
or use a file....
11th Mar, 2009 at 01:46:55pm
So it's all about the position of the diaphram spring? On 7th Nov, 2008 Nic said:
