| Home > Help Needed / General Tech Chat > 850 Cranks | |||||||
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
9th Mar, 2009 at 09:37:18pm
Hi chaps, i've searched and yet i cannot find the answer; even though im sure i've seen it.
Edited by Oli on 17th Mar, 2009. On 15th Jul, 2009 fastcarl said:
the pissed up clown stood back up, did a twirl and left bollock naked, |
9th Mar, 2009 at 09:48:08pm
Apparently its 68.26mm.
9th Mar, 2009 at 10:35:44pm
yes you are Correct!
10th Mar, 2009 at 07:10:48pm
17th Mar, 2009 at 08:14:13pm
Hi, had another question, and had no reason to start a nw thread.
17th Mar, 2009 at 09:16:07pm
No it won't fit. The journal size and spacing is all wrong.
17th Mar, 2009 at 09:19:00pm
I heard tell of one being fitted in an S block befour but cant rember where I seen the article. As will says the spacings are different On 17th Feb, 2009 Rob H said:
17th Mar, 2009 at 09:40:01pm
Hmmm i thought something like that might be the case, worth an ask, try something new and all that.
17th Mar, 2009 at 10:06:43pm
On 17th Mar, 2009 PaulH said:
I heard tell of one being fitted in an S block befour but cant rember where I seen the article. As will says the spacings are different It's not the spacing that's the main issue bar the size of the mains. You'd need main bearings thicker than Nic's right forearm. There were once cranks available that made a big bore block 850cc, but that's a different story. On 13th Jul, 2012 Ben H said:
