Home > Help Needed / General Tech Chat > Steering Column Lengthening & U-Joints
moke123
Member #: 4584
Perth, Australia
I'd like to lengthen the steering column and probably add one or more u-joints so that I can move the seats back further on my Moke and get the steering wheel in a better position.
Can anyone offer advice on how to do this?
Graham
Ben H
Member #: 184
Melton Mowbray, Pie Country
I was going to say have a look at a maestro or montego column as a replacement, then I looked at your location.
http://www.twin-turbo.co.uk
jukka
Member #: 60
Forgotten more than most ever know
IIRC a late 80 / early 90´s Mazda 929 had the same splines as Mini / Minor rack. You might find these easier than other British makes. If you solve that problem there is a potentially harder one: how to fit the column securely in position. It does require all kind of bracing and it is somewhat difficult with a Moke. But anything is possible.
moke123
Member #: 4584
Perth, Australia
Thanks Jukka. At one time I had a supplier's website address that carried splined column ends of the same kind as Mini, but can't seem to find it now...
I'm sure I was told Mk2 escort UJ's are the correct spline.
http://www.16vminiclub.com/forums/viewtopi...ight=mk2+escort
http://www.gartrac.com/store/erol.html?690x0#5057X7937
http://www.rallydesign.co.uk/product_info....roducts_id=7333
moke123
Member #: 4584
Perth, Australia
Thanks very much Dave. The Rally Design site is the one that I had lost. Now I can start designing again. As with many vehicle mods in Australia, I'll have to get it certified by an engineer to make it road legal.
Cheers, Graham
