Home > Help Needed / General Tech Chat > N/A to turbo
Dave1293
Member #: 5477
Hi guys,
I currently have a 1293cc n/a tuned engine, i would like to turbo it, i have someone willing to mod my head... but i think i'm going to need to do more to lower the compression? i think i have 6cc dish omega pistons which someone said i could prob dish out to 8cc.. with a 4cc head gasket would that be enough? I would like to run between 10 - 12psi... I did try searching but im late for work now..
Cheers guys
1293cc 86bhp @ Wheels soon to be turbo'd
ATSPEED RACING - http://www.atspeedracing.co.uk/
Atspeed Racing 106 Turbo - http://www.youtube.com/watch?v=h5JDis-T8f0...=5&feature=plcp
Have a good read in Beginners Tech and How to sections. Everything you need to know is in there.
How many cc's will the head have?
Dave1293
Member #: 5477
I'm not sure.... Turbo Phil (on The Mini Forum, he must be on here too) said he would do some work on them. What does a standard head have? Turbo heads normally 28cc right?
If you can get 28cc's in the head, then you should have a CR of 8.6:1 with your current 6cc dish.
I think that's right?
Dave1293
Member #: 5477
would 8.6:1 be ok to run around 12psi or should i change to 10cc dished pistons... i don't really want to run the risk of a meltdown. MED do some die cast 10cc pistons for £280 which isn't to bad.
Also going for the avonbar phase 2 cam, megajolt and have a Uno turbo intercooler.
Cheers for the advice guna go check out the beginners tech posts
welcome to the forum dave, i would get those 11 cc omega cast pistons they are well proven for turbo use.
and while you are at it maybe have it bored & honed the next size up, you then have a new engine.
Dave1293
Member #: 5477
Out of interest... how many people on here have high compression low boost engines? what do you think of these? I have been given some ideas.
If the current engine is good, it may be worth selling it and starting fresh if youre going to the effort
Paul
I used to run mine at 9.6:1 and ran quite alot of boost. It did pink in warm weather though. *oh well* They are good for a daily drive if you limit the boost to stop pinking, the engines are really smooth and quite responsive (even with a T3). At the end of the day its just an N/A with a turbo bolted on the side at that CR.
You can get an engine with a lower CR to drive well too by selecting the right sized turbo. There is no point running a really low CR if your not going to run high boost, it will only become more slugish off boost...its all about compromise. *wink*
and economy with running low CR running under 8psi boost
tadge44
Member #: 2500
Buckinghamshire
Dont know what counts as high C/R in this context but I,m running 8.8:1 and up to 16 psi - so far so good.
Im also running 8.8:1 and it works really well for me. TBH I think its a good compromise, especially as most of my miles (and yours I guess) and road miles. Still building my clutch to take more than 10psi though! *hehe!*
tadge44
Member #: 2500
Buckinghamshire
Thata the advantage of rear wheel drive and Ford clutches !!
I'm glad to see you're putting the head i did for you through it's paces ! :)
