| Home > General Chat > Oil Return Location | ||||||
12th Mar, 2009 at 06:52:29pm
What are peoples thoughts on this Idea. Im thinking of make a little adapter that will fit into the speedo drive hole, that will accept a pipe from the oil return on the turbo, I will also mod the speedo drive housing by drilling a couple of holes in it to aid the flow of the returning oil?
12th Mar, 2009 at 06:57:33pm
mike, the oil has to go in above the oil level , is it possible that on hard corners that place could be below the level ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
12th Mar, 2009 at 06:59:19pm
Yes good point robert, i hadnt thought of this! BTW what thread are the outlets on the turbo? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
12th Mar, 2009 at 07:06:17pm
no idea , mike , i just went to the hydraulics shop and got them to make me a pipe that had a compression fitting for the steel metro turbo feed pipe ,which i cut just above the clutch. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
12th Mar, 2009 at 07:38:48pm
I use the speedo cable hole as a drain from my breathers, seems to work ok On 15th May, 2009 TurboDave said:
12th Mar, 2009 at 07:50:57pm
Hmm, wouldnt this differ with a turbo tho? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
