| Home > Help Needed / General Tech Chat > swaged fuel pipe ends? | |||||||
297 Posts Member #: 2276 Senior Member sheffield / derby |
13th Mar, 2009 at 08:25:46pm
549 Posts Member #: 5327 Post Whore Dudley, West mids |
13th Mar, 2009 at 09:07:11pm
There is a tool you can buy. I brought a brake pipe flaring kit from machine mart. In it you get various flared die's. Did all my brake lines with it and it worked a treat. Only cost around £25 for the kit. For the brake lines you use the smallest die so I'd imagine that you use a mid sized one in the kit to do your hoses. You'd find it tricky doin it without this kit mate. :) |
13th Mar, 2009 at 10:17:00pm
I no merlin motorsport do that. obviously not ideal if youve got long ones to post.
13th Mar, 2009 at 10:38:06pm
It is a fab idea but not needed, a well tightened Jublee type clip works very well, tried and tested.
13th Mar, 2009 at 11:02:07pm
Ive been looking around the internet and aparently others have said they need swaged type bits like this to pass an sva test which is why i thought they're might be a tool for it. im not too sure myself as i was just wanted to be sure there was no chance of a fuel leak.
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
13th Mar, 2009 at 11:02:36pm
just do them up tight,
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
13th Mar, 2009 at 11:07:50pm
SVA? this ain't a kit acar forum!!..
13th Mar, 2009 at 11:11:12pm
if you buy Sytec or Webcon fuel hose of the right size, once its been pushed onto the metal pipe, it takes a huge force to pull it back off again, without any pipe clips!!!! I doubt its going anywhere :) On 26th Oct, 2004 TurboDave16v said:
13th Mar, 2009 at 11:15:45pm
yep to reiterate above, just get some decent hose clips. On 28th Aug, 2011 Kean said:
14th Mar, 2009 at 04:48:50am
And check them once in a while, as the pipe compresses and the clips can be tightened up. |
