| Home > Help Needed / General Tech Chat > piston info | |||||||
![]() 16 Posts Member #: 2095 Member Dongen Netherlands |
13th Mar, 2009 at 11:28:06pm
hi,
14th Mar, 2009 at 10:49:15am
Thats not the original turbo piston (20831)...
AlexF |
14th Mar, 2009 at 06:51:39pm
Really surprised you cannot find any info on that one, Try here > www.google.co.uk Edited by Sprocket on 14th Mar, 2009. On 26th Oct, 2004 TurboDave16v said:
14th Mar, 2009 at 07:05:59pm
isnt the turbo piston 22357 ? Edited by robert on 14th Mar, 2009. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
14th Mar, 2009 at 08:15:13pm
Their may be a couple of numbers, but I think most would be 20831's On 7th Oct, 2010 5haneJ said:
15th Mar, 2009 at 05:56:14pm
21251s are shite pistons sorry. They have no place in a Turbo-engine.
15th Mar, 2009 at 06:07:43pm
15th Mar, 2009 at 07:04:56pm
On 15th Mar, 2009 Sprocket said:
What makes them shite V? Slot behind the oil ring, inferior alloy to the 21253 for instance, and wide ring pack. Not to mention the fact that they don't come anyhere near the top of the block at TDC. Edited by Vegard on 15th Mar, 2009. On 13th Jul, 2012 Ben H said:
15th Mar, 2009 at 07:28:13pm
so the do come to the top of the block then??
On 15th Mar, 2009 Vegard said:
they don't come nowhere near the top of the block at TDC. On 28th Aug, 2011 Kean said:
15th Mar, 2009 at 07:30:03pm
21253 also have a taller crown 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
15th Mar, 2009 at 07:52:47pm
Pardon?
On 15th Mar, 2009 mini13 said:
so the do come to the top of the block then?? On 15th Mar, 2009 Vegard said: they don't come nowhere near the top of the block at TDC. On 13th Jul, 2012 Ben H said:
15th Mar, 2009 at 07:54:53pm
I once heard 21251's described as cadbury chocolate pistons. Edited by John on 15th Mar, 2009. If something is worth doing, it's worth doing half of. |
15th Mar, 2009 at 07:58:56pm
"don't" and "nowhere" is a double negative Vegard. Do come along.
15th Mar, 2009 at 08:46:42pm
so the do come to the top of the block then?? On 15th Mar, 2009 Vegard said: they don't come nowhere near the top of the block at TDC. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
15th Mar, 2009 at 09:02:22pm
On 15th Mar, 2009 Tom Fenton said:
"don't" and "nowhere" is a double negative Vegard. Do come along. I was confused by the "the" which probably was supposed to be "they". On 13th Jul, 2012 Ben H said:
15th Mar, 2009 at 09:20:24pm
well mine was just a typo, your was horendous grammer! On 28th Aug, 2011 Kean said:
15th Mar, 2009 at 10:21:27pm
What makes them shite V? Slot behind the oil ring, inferior alloy to the 21253 for instance, and wide ring pack. Not to mention the fact that they don't come anyhere near the top of the block at TDC. The oil slot is the same as the 21253
15th Mar, 2009 at 10:45:12pm
they are mostly a budget piston 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
16th Mar, 2009 at 05:43:10pm
thanx for the info
16 Posts Member #: 5477 Member Essex |
18th Mar, 2009 at 07:13:36am
MED do some good stuff... i'm going for the +20 die cast omega with a 10cc dish... only £280 for the set. 1293cc 86bhp @ Wheels soon to be turbo'd
18th Mar, 2009 at 07:14:56am
http://www.med-engineering.co.uk/product_d...62&vlang_id=106 1293cc 86bhp @ Wheels soon to be turbo'd
18th Mar, 2009 at 08:16:39pm
thanx for the help
or here
