Home > Help Needed / General Tech Chat > 1340 NA runs bad above 5500 rpm
remko
Member #: 1956
We have a problem with one of our minis. From 5500 rpm it runs bad. It looks like ignition can't handle the high rpm. The problem wasn't there before, it was running well with this setup. It's a NA 1340 with Sidedraft Webber and aldon ignition (points) Everything in ignition area is renewed (points, rotor, cap, spark plugs, spark cables). Car was a few months adjusted ago on rolling road.
Has anyone any ideas what to check?
Regards,
Remko
Edited by remko on 14th Mar, 2009.
philc
Member #: 1346
bromsgrove
timing? when was it last rr
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Broken valve spring ?
"Try to take over the world!"
insuficient fuel pressure / supply problem
i would firstley change the coil then check out all the leads dizzy cap etc then go for the rest
hope this helps please keep us informed
madcatminis
Member #: 5327
Dudley, West mids
Check that all electrical connections are a tight fit. Mine came loose once on my 1330cc and it run like a bag of crap. Only found this out when i knocked it with my hand with the engine running. :)
remko
Member #: 1956
OK thanks! We'll do the electrical checks again and we are going to install a lambda-sensor to check the mixture. We'll keep you informed!
Regards,
Remko
Edited by remko on 16th Mar, 2009.
