| Home > Technical Chat > Definitive Flow Figures for different Heads | |||||||
Site Admin ![]() 9407 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
14th Mar, 2009 at 08:17:17pm
Here are some flow figures for some different heads, can you guys add to this.
14th Mar, 2009 at 08:33:46pm
can we not have more accurate indepth figures ie,0.100,and 200 300 400 500 600 of lift, this will give a beter idea of what is going on,
1391 Posts Member #: 1686 Post Whore Oxford |
14th Mar, 2009 at 08:36:53pm
Intresting, like carl says but even then it gives me a rough indication or what mine is flowing. Edited by Sam on 14th Mar, 2009. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
![]() 6753 Posts Member #: 828 Post Whore uranus |
14th Mar, 2009 at 09:01:35pm
theres the fiat punto 1243cc head ,stock is lowest ,and porting so far are the next 2 lines .tested at 28".
Edited by robert on 14th Mar, 2009. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
14th Mar, 2009 at 09:05:59pm
we definately need to know what pressure drop the tests were done with ,the results can then be corrected back to a standard pressure drop and compared . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
14th Mar, 2009 at 10:02:13pm
Interesting stuff, as Robert says though we need the test pressure used.
14th Mar, 2009 at 11:13:00pm
the 7 port will be coming out shortly to go on the new bottom end if any on wants to pop it on a flow bench.
1425 Posts Member #: 690 Post Whore Norfolk |
14th Mar, 2009 at 11:22:32pm
Carl getting all technical..ooohhh come on then put a kad head up for scrutiny - I'll do the same with the K16v and stg 1 k16 when I'm not drunk!
If Carling made Mini engines
15th Mar, 2009 at 01:12:19am
15th Mar, 2009 at 08:10:06am
JOhn, i tested a few heads a in the past, i thought i knoew where all the data was, unfortunatly it does not appear to be where i left it,
15th Mar, 2009 at 09:36:58am
bugger ,shit and knob.
15th Mar, 2009 at 12:57:30pm
Carl - you're meant to keep them on this computer thing!! If Carling made Mini engines
15th Mar, 2009 at 02:21:32pm
On 15th Mar, 2009 johnK said: if i'd have done that they would be history by now with my HD failure early last year,
Carl - you're meant to keep them on this computer thing!! i nkow ive moved them somewhere safe , just don'y know where, |
15th Mar, 2009 at 06:13:24pm
Carl - you're meant to keep them on this computer thing!! i nkow ive moved them somewhere safe , just don'y know where, 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
15th Mar, 2009 at 10:21:23pm
No Mike,, the flow figures deffo didn't fall through a HOLE IN MY FOOKING POCKET,lol
On 15th Mar, 2009 MikeRace said:
Just like your keys
On 15th Mar, 2009 fastcarl said: On 15th Mar, 2009 johnK said: if i'd have done that they would be history by now with my HD failure early last year,
