| Home > Help Needed / General Tech Chat > additional engine/gearbox steadies | |||||||
14th Mar, 2009 at 10:45:47pm
hi, after fitting the bulkhead box i have lost the mount point for an ultimate engine study.
14th Mar, 2009 at 11:15:13pm
I have front and back gearbox stedies as well as the standard engine steady and i have 0 movement
15th Mar, 2009 at 01:00:31am
I only use 1 steady at the top, albeit a solid one. No movement at all. |
Site Admin 6297 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
15th Mar, 2009 at 01:06:31am
You can still use the ultimate engine steady - you just need to move the mounting location a bit.
15th Mar, 2009 at 07:26:16am
best steady(s) in my opinion are the 2 that go from the diff housing back to the subframe legs, i cannot have the ultimate steady due to the way the bulkhead box was cut, i cant move it over enough with out hitting the radiator either Yes i moved to the darkside |
15th Mar, 2009 at 09:20:10am
I managed to keep the ultimate steady on mine, just make another bracket up. |
15th Mar, 2009 at 09:30:56am
On 15th Mar, 2009 AlexB said:
You can still use the ultimate engine steady - you just need to move the mounting location a bit. Mine mounts about 3" to the right of the original location If it wasn't your site I would make a rude comment here! Al right I will anyway Ultimate POS more like! On 5th Sep, 2011 Vegard said:
20th Mar, 2009 at 05:05:17pm
pics anyone? |
