Home > Help Needed / General Tech Chat > Boost Retard setup
NeXTGen
Member #: 255
Has anyone had any experience with the Microdynamics EMS5 Boost retard set up?
Have aqquired one, and was wondering if anyone else has had any good/bad/indifferent tips for setup/running, or where to get a boost pressure switch from. (note - I'm an electronic engineer, and dont mind doing stuff like cooking up an adapter box for an electronic sender to switch over at a given boost - i.e. op-amp, set point, output + possible relay). I dont really want to spend fifty quid on a part I could get from the scrappy and then make work!
Cheers.
Microdynamics stuff is from the dark ages...
Check in farnell and puirchase a suitable pressure sensor and use that along with your skills...
