| Home > Help Needed / General Tech Chat > ring gear ID | |||||||
20th Mar, 2009 at 07:00:53pm
Hi hads anyone know the ID of a pre verto ring gear and the ID of a Verto ring gear,
On 17th Feb, 2009 Rob H said:
20th Mar, 2009 at 08:00:39pm
It should be the same. On 13th Jul, 2012 Ben H said:
20th Mar, 2009 at 08:01:59pm
^^^ Correct (of course) ^^^ On 17th Nov, 2014 Tom Fenton said:
20th Mar, 2009 at 08:09:04pm
On this subject, what ring gear do I need to use a pre-engaged starter,in place of the one for inertia starter ?.
20th Mar, 2009 at 08:37:33pm
I could still do with the ID if poss my calipers just dont go to it,
20th Mar, 2009 at 08:39:00pm
On 20th Mar, 2009 tadge44 said:
On this subject, what ring gear do I need to use a pre-engaged starter,in place of the one for inertia starter ?. ( and where can I get one ?.) You need a 127 tooth gear for a Mini pre-engaged starter. Will that fit on your spridget flywheel? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th Mar, 2009 at 09:21:59pm
On 20th Mar, 2009 PaulH said:
I could still do with the ID if poss my calipers just dont go to it, regards, Paul. if i remember i'll measure tomorrow |
20th Mar, 2009 at 09:45:06pm
Thanks a bunch Carl your a star Ill owe you a beer :) On 17th Feb, 2009 Rob H said:
20th Mar, 2009 at 10:53:20pm
Paul -not sure,I have no idea of the relative diametewrs of the Mini and Midget flywheels, but the Marina /Ital used a pre engaged starter with some models, so there must be an option there somewhere,I guess. This is probably the wrong forum to raise the isssue, sorry guys. |
24th Mar, 2009 at 06:37:57pm
as far as i can tell , measureing with two digi vernier it measures 9 and 5/8 ", ,
