Home > Help Needed / General Tech Chat > adding a brake servo? worth it?
Welsh Turbo
Member #: 374
my current setup is the older type with no brake servo, just a good old master cylinder....
is it worth upgrading and fitting the later type system that uses a servo? cuz i used 2 get scared running the 998 never mind the new engine although it only had the solid 8.4 disks on front and drums on back!
what would be the best route to take?
Edited by Welsh Turbo on 18th Oct, 2004.
Mike
Member #: 107
Sunny Sussex
ok, i'm non-turbo (at the mo:)), but i use the usual 4pot vented setup and its pretty bloody good for me.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
All a servo does is reduce the physical effort required to stop the car... it does not improve your braking!
So if you want a lighter pedal go for it (most do) but you need to start matching caliper piston sizes and master cylinder sizes carefully without a servo.
Alex
AlexF
Kean
Member #: 341
aka T2clubby
South Staffs
Most people with turbos probably remove the servo to make more room for the important stuff..... you know things that make you faster not slower *happy*... joking aside, a well maintained non servo system is just as good as a servo if your leg is up to it
I prefer the feel of non assited brakes anyway
Yep i prefer non servo too *happy*
just on cooper s brakes me *smiley* have had them on the last few cars and usually been fine when in good nick but once they neglected they detriorate very quickly.
Welsh Turbo
Member #: 374
cheers guys, looks like ill save some cash and room and stick with the good old setup then. its a new master cylinder on there any way
will i need to make any changes to it to fit metro turbo disks and calipers?
Kean
Member #: 341
aka T2clubby
South Staffs
if your runnin on 12/13 inch wheels not really as long as your master cylinder is up to it
Some of them can't displace enough fluid to move all the pistons....
The later tandem type cylinder has a bigger bore i think
Edited by Kean on 18th Oct, 2004.
Not sure if you got a bit mixed up there?
The different bore sizes are used to give a different line pressure, as it is this that modifies the effort you need to put into the pedal. The amount of fluid displaced doesn't really affect anything, apart from when you have fitted new pads, and are pumping the pedal to push the pistons back out to contact the new pads.
As the bore of the cylinder goes down, the line pressure increases, and so you have to push less-hard for the same braking effort.
Vice-versa, if the bore of the cylinder goes up, the line pressure goes down, so you need to push harder to get the same braking effort.
Welsh Turbo
Member #: 374
ok. am i right in thinking you need a new set of braided hoses to go to the calipers?
yep. i can do these for a good price *smiley*
Welsh Turbo
Member #: 374
when i find some disks and calipers then ill get in touch!
also need an engine.... fuel tanks...... the list is endless!
jukka
Member #: 60
Forgotten more than most ever know
Latest spec tandem cylinder with integral servo does have a bigger bore, 20,8 mm I believe. I have this setup with 4-pots and it is great. Well guys you need to consider that I am almost 40 and loosing the body strength bit by bit. Besides, the wife also drives the car so it is better for her.
Learn something new every day! *happy*
