Home > General Chat > Makes my blood boil
Started work on prepping Sturgeo's Flame to sell it.
It's in reasonably good condition except the front paint work was crazed and a door was badly rotted.
Sturgeo has removed the paint from the front wings and front panel which appear to be realtively new.
I only wanted to take the door off to fit a new skin, but the nuts were buried in goo.
Started to remove the goo to find massive holes.........so the A panel had to come off.......
Bl@@dy Bodging B@st@rds.
Why go to all that trouble to replace the panels over the top of a load of crap.
Edited by Paul S on 21st Mar, 2009.
looks a bit like my clubby did last weekend. I managed to repair it with the A Panel etc still on. Not fun is it!
I think I've found the last load of bodges on my black clubby. Somebody had fitted a boot hinge repair panel, but put it in the wrong place and ended up putting a 1/4 inch of filler over the top. There where bodges like that all over the car!
Minis are being sold like that as, solid, mint condition and fetching stupid money.
Anyone who saays there is no rot in their mini that is worth £2500, is either lying, unaware, or undervaluing their car
Very true, but I'm not prepared to sell it in that condition, particularly as it will be advertsied here first.
It's not going to be perfect when we sell it. It will need sills in a couple of years. Plus the other inner wing will need some work at the same time.
Anyway, I've cut out all the rot and £20 worth of panels will see it sorted.
Problem is the time. I wanted this car off the ramp by the end of the month so that we could start preparing the Miglia for Avon. It's the outlaws golden wedding next weekend so running out of time.
Been busy with the grinder.
Still some more to cut out!!!!
i had the same issue last year mate, i did a flip front for a so called friend but spent so much time on rust repair i could not spent as much time doing a flip front, we fell out as he was slating me for taking to long, bearing in mind i was doing it as a favour that was out of order
Ollie
Member #: 1380
I wonder if Paul has got out a baseball bat with his repair yet Neil.
I'm still mentally scared from when you pulled that out and started beating the crap out of it lol
Mini_Andy
Member #: 432
thats bad!
out of interest how much are the replacement panels for the inner wing? i want to replace mine when i fix it up properly, due to money issues at the moment i had to patch it u in 3 places. But at least i bloody did it with metal nd welded it on!
The bit that goes from the panel flange round to corner of the inner wing are about a tenner.
Been there, done that and got the teeshirt.
There are some shockingly bad Minis out there.
I'm actually glade that I brought my clubby and found all the rust / filer / bodges with the angle grinder. I don't want to think what would have happened if a kiddie had brought it and then been involved in an accident.
EDIT: My metal work isn't and will never be the prettiest but it is solid.
Edited by Rob H on 22nd Mar, 2009.
druid
Member #: 4636
Uk milton keynes
Good god thats sh*t.
I had a bad water leak, and couldnt find it until i got it on a ramp and found some bodging get hadnt even welded the two new floor pans up properly!!!!
and used bathroom sealer to try and hide the weld or lack of it!!!
If you carnt do it give it to somone who can *Clapping*
sent my british open classic away to have a new battery box, arches patched and a full respray, came back with bits of metal, and the battery box glued in with seam sealer. the guy hadnt touched it with a welder!
bac!
Carl
Member #: 95
liverpool-on-sea
i bought a cooper once and the oversills had been bonded on, that pissed me off a little.
