Home > Help Needed / General Tech Chat > help!
turbosteve
Member #: 370
Reads "my mates" max power whilst wearing my Mrs's underwear
any one got a slave bracket like this, i cant figure it out... how the hell does the slave mount onto that weird thing !
billydude
Member #: 48
Leicester
thats a metro cable mount *wink*
not slave mount
Welsh Turbo
Member #: 374
slap me if im wrong, but cant you just remove that bracket nd mount the slave onto the bell housing, or are the bolt holes different on the mini bell housing to the metro turbo one?
Edited by Welsh Turbo on 18th Oct, 2004.
billydude
Member #: 48
Leicester
that end cover and bracket are no use in a mini
you need the hydrolic operated clutch end cover and slave bracket *wink*
have fun changeing it *laughing* Lol
turbosteve
Member #: 370
what is it doing on my car ! lol its been pissing me off for weeks, so do you guys reckon i should buy a new bracket and slave, it should fit ok right ?
billydude
Member #: 48
Leicester
turbosteve
Member #: 370
ha ! lol its for a bloody cable type operated clutch omg what a mong i am.
sorry mate when you say end cover you mean the whole end casing ? i dont fancy doing this !
billydude
Member #: 48
Leicester
yup as far as I know the end caseing is different but you might get away with fitting a hydrolic clutch arm in the cable case
Nope your wrong billy *smiley* , the end casing is identical, just needs the arm changing and correct verto bracket buying *smiley* plus associated slave and pipes
billydude
Member #: 48
Leicester
I said maybe *blush* *laughing*
thats ok then! lol *happy*
turbosteve
Member #: 370
having problems finding secoundhand slave ect, minispares sell them new and the brackets also, need to ask is the pin that connects the arm to the slave actually part of the slave or seperate ?
nutter driver
Member #: 47
Not very sunny swanage
the pi n you are refering to is acually atatched tot the end of the arm, and simply locates inside the slave. which bits are you needing? im pretty sure ive got a complete verto system in my shed if you need any bits?
hth,
pete
turbosteve
Member #: 370
mate if you can find the parts great ! i can send you some cash, or pay by paypal, as you can see by the pic i need everything, arm, slave, bracket pins ect, the master cylinder i got.
can you let me know asap as i need to get my motor on the rd !
cheers
steve
turbosteve
Member #: 370
sorry to prolong this thread but on my arm theres seems to be a lot of play(in and out) about half inch or so, is this normal ?
yeah its just where your pulling the clutch bearing away from the clutch, as long as you adjust it as per haynes it will be fine.
nutter driver
Member #: 47
got to go and meet my grand parents for lunch in a minute, but ill have a look when i get back, if i havent posted on here by late this evening, then send me a pm cos ive forgotten!
nutter driver
Member #: 47
right got back and been hunting in the shed, amongst a shit load of other stuff i'd forgtten i had, ive found a verto slave mounted on a verto bracket with a verto arm cable tied to the end of it. (actually the fact that its all still together would suggest i didnt take it off, because i normally throw everything in a pile rather than being methodical about it! so dont know where it came from? lol!)
been sat in the shed for a couple of years (maybe longer) so could certainly not guarantee it would work ok. The bracket and arm look fine, (not too sure anything other than the little ball wearing goes wrong with these anyway) but the rubber on the end of the slave looks none too hot, may still work tho.......
havent got the bits that go on the 'wok' but iirc you can just take the split pin out, push the clevis pin out, put this arm in, and reinstate clevis pin, and chuck a new split pin in.
If its any good to you let me know,
Pete
Nick
Member #: 154
Midlands
the slave rebuild kits are only about £3 anyway from most motor factors. all it is is a new rubber boot for the end and a seal inside.
turbosteve
Member #: 370
hi mate, thanks alot for sorting through your junk lol
email me with how much you want for it, i'll chuck a fiver on top as well for p&p and for your time
thanks
steve
email me
spbailey101@aol.com
for some reason i cant private on the site or receive, cheers
nutter driver
Member #: 47
email sent!!
btw, its not junk!!! *wink*
