| Home > General Chat > Crank Pulley! Loose! | ||||||
559 Posts Member #: 2775 Post Whore Aberdeen |
22nd Mar, 2009 at 01:06:44pm
Hi Guys. Has anyone ever had a crank pulley come loose? I have a 1310 with a supercharger and last night I dug it out the garage for the 1st time in ages as the tax runs out next week. Anyway I was giving it some stick and it started to sound non too healthy under load, and my clutch felt a little unusall. Anyway to cut a long story short when I got it back to the garage it appears my crank pulley has been floating in and out. I havent got as far as strip it down but has anyone ever had htis or heard ogf this happen? ( I havent) The bolt went in with a new locktab washer etc when I fitted the charger. Is it likely to have come loose or am I likely to be looking at something more sinister? Good it be badlt damaged thrusts? I am just looking for peoples thoughts.
22nd Mar, 2009 at 01:18:16pm
Thrust bearings wont have any effect on the tightness of the bolt.
22nd Mar, 2009 at 01:22:22pm
It was more the movement I have on the pulley I was worried about as it can be moved in and out. I ran out of time last night but when I got my fingers on the bolt I couldnt move it. |
22nd Mar, 2009 at 02:17:24pm
If you mean the pulley is shifting in and out while running, and you think your clutch felt different, its screaming thrust bearings to me!
22nd Mar, 2009 at 02:22:02pm
Sounds like bunched trusts On 17th Feb, 2009 Rob H said:
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
22nd Mar, 2009 at 03:11:29pm
Yes my crank pulley was very loose when I came to remove the pulley so it could get machined. Quite worrying really!
22nd Mar, 2009 at 03:23:20pm
ive had one come loose aswell, found the bolt on the floor of my dads garage dont know how long it had been there but the engine mount held the pully on, std 998 just after i had got it Yes i moved to the darkside |
22nd Mar, 2009 at 04:47:08pm
I have had my trigger wheel come loose, not sure why though |
22nd Mar, 2009 at 09:34:32pm
Well the pulley was as tight as the day it was fitted. So it looks like the whole lot has to come out now |
. Just as we were getting some decent weather. Well at least I know I dont have to tax it at the end of the month.
