| Home > Help Needed / General Tech Chat > OT - how to 'ping' com1 to check it is working? | |||||||
22nd Mar, 2009 at 02:16:38pm
I've had a new HD and everything installed on my laptop, but now can't get my data aq software (that works thru com1) to talk to my laptop. I know that when I first set this up through my COM1 serial few years back the supplier of the unit talked me thru pinging my com port to check it was working.
928 Posts Member #: 65 Post Whore South Yorkshire |
22nd Mar, 2009 at 08:48:54pm
The only way I know of is to do a loopback test
23rd Mar, 2009 at 08:10:59am
Yep that is all I would do. Short out pins 2 & 3, then in hyperterminal you should see the letters you type appear. http://www.twin-turbo.co.uk
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
23rd Mar, 2009 at 08:41:38am
sure your baud rate is set up correctly, hyperterminal may not default to what you need.
"Cars are a lifetime of pain" |
23rd Mar, 2009 at 07:37:18pm
if you have the fifo buffers engabled, try turning them right down or disabling them, it can play havoc with real time data streams and some legacy stuff sure youll find it in my computer - device manager - serial port turbo 16v k-series 11.9@118.9 :)
23rd Mar, 2009 at 08:11:08pm
Well, it was working all along - I was just being a dumbass and still had it looking for a CAN signal rather than Autosense... I did the stuff in the link above, which was very useful! Thanks On 17th Nov, 2014 Tom Fenton said:
1st Aug, 2009 at 05:38:06pm
WTF,
1st Aug, 2009 at 06:50:37pm
thats cause you have an option to "echo characters locally" or something checked in hyperterminal :) un-check it. turbo 16v k-series 11.9@118.9 :)
1st Aug, 2009 at 07:20:55pm
hmmmm,
1st Aug, 2009 at 09:01:27pm
That's likely because it's not a real physical com port but a loop back com port. This is used for testing and can't be used for comm. Your actual com port is on another number.
2nd Aug, 2009 at 10:25:12am
thats interesting Jean,
