Home > Help Needed / General Tech Chat > What to keep??
Nic G
Member #: 5583
Cannock
Hello, my project as kind of kicked off today, i brought a bare metro turbo challenge engine and picked up a mini yesterday with a 1275 in, what can i use from the 1275 engine eg starter motor that kinda thing?
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
All the ancilliaries are exactly the same!!
Nic G
Member #: 5583
Cannock
Can I use the flywheel?
Is your 1275 donor engine A or A+ ?
Nic G
Member #: 5583
Cannock
Its an A+
keep all the parts Nic they will come in handy for you one day!
The obvious bits you need from the Mini are the engine mounts, especially the bits of steel brackets (and alloy adapter block) at the fan end as the engine is mounted differently to the Metro.
Be careful about the flywheel and starter motor - the combination of ringgear teeth and starter motor pinion is different on a pre-verto flywheel with an inertia starter compared to a verto flywheel with a pre-engaged starter..... and some of the aftermarket flywheels have non-standard ringgears anyway.
But, as above, I would keep everything you can, certainly at least until you have it running the way you want.
Edited by Rod S on 23rd Mar, 2009.
