| Home > Wanted > Avonbar Phase 2 Cam | |||||||
![]() 338 Posts Member #: 1911 Senior Member Swindon |
23rd Mar, 2009 at 06:48:24pm
Hello, as above and just seeing if anyone has one they won't be using even though this is a slim chance but just checking before hand. |
23rd Mar, 2009 at 08:51:44pm
Avonbar £68 reprofiled one
23rd Mar, 2009 at 08:56:03pm
Do they still do reprofiled cams? I thought it was billet only now? If something is worth doing, it's worth doing half of. |
24th Mar, 2009 at 07:29:16am
Ok might sound like a stupid question, but what's the difference in it besides weight? nothing? |
24th Mar, 2009 at 07:47:25am
Re-profiled means they regrind an existing cam to get the new lobe shape and as the new lobe will inevitably need to be "longer" than a standard cam, the only way it can be done is by grinding the whole lobe on a smaller diameter base circle. Also if lift is being increased, the base circle must be made smaller.
24th Mar, 2009 at 07:52:02am
Hmm right ok. Suppose I could have it done and run everything new and just have a look in a years time to inspect wear. |
72 Posts Member #: 5062 Advanced Member Herts |
27th Mar, 2009 at 12:03:51pm
Avonbar are deffinately still re-profilling the ph2, i've just had one done. |
