Home > Help Needed / General Tech Chat > Oil temp sensor
quinton
Member #: 1911
Right just got my oil temp gauge and its the capillary type. Does anyone off the top of there head know what thread this is?
5/8 unf
Sprox: Do you know if the Racetech capillary gauges are 5/8UNF as well?
were you thinking about getting one of those sandwich plates for the oil filter?
im thinking about ordering one and drilling tapping it out (if poss) wopuld anyone know offhand if this is possible? is there enough meat in them?
I can have a measure of mine later if you like
*Rofl!*
child
No, I'm fitting mine int he sump. On the other side for the sump plug.
I have mine in the sump now Vegard, but...does it matter what temp the oil in the sump is?
Isnt it the oil temp in the galleries (after pump) thats important?
and I have feeling that there will be quite a difference?
I've got mine and the vans in the speedo housing. However I do have a sandwich plate so may move the sensor to that as a test at some point.
I think Jim might already have some comparisons, but not sure, i was looking into it the other day here:
http://www.turbominis.co.uk/forums/index.p...&tid=4569&fr=50
Well, unless you run a cooler I don't think that the temerature is that different. I once promised to check this for Jimbo but I've never come around to do it.
I'm not running a cooler on this engine, so sump is A OK I would believe.
hopefully the case, but i would have guessed that oil @ atmospheric pressure vs. said oil @ say 70psi, would be substancially different?
probably wrong, but .....?
I dont know V, the one I have was a TIM gauge, and I dont know why I adamently said it was specificaly 5/8unf when I didnt know what gauge it was, lol.
i turned up an adapter so my sender fits through the sump plug,
In Ti I hope *wink*
http://www.minispares.com/Product.aspx?ty=...3002&title=SUMP PLUG OIL TEMP ADAPTO...
Edit: Just been on the phone with DT. The Racetech gauge is 3/8 BSP.
Now where do I find such a tap *wink*
Edit2: I just had a look around as I did feel that 3/8 did seem a bit on the small side. Have googled it, I now see that the drill size for a 3/8 BSP is 15.25mm...
Where the 3/8 comes from I have no idea..
Several taps on Ebay though.
Edited by Vegard on 13th Mar, 2010.
