Home > Beginners Tech > mini cooper 1.3i spi
Mini cooper monte carlo
Member #: 5638
Hi,Can anybody help i have recently bought a mini cooper 1.3 spi 1995 Nreg,unfortunatly the big end has gone so im in need of a new engine,so can any 1275cc engine fit for example mini/metro etc i know the injection manifold will have to be changed or perhaps i could put my head onto the new block but again would it fit???any help would be much appreciated.
Everything is interchangeable between the spi engine and a standard carb mini/metro 1275.
You will need to swap over the flywheel and transfer housing as the spi mini has a crank position sensor and markers on the flywheel.
Other than that should be a straight forward conversion.
Does it actualy need a new engine, or could the one you have be rebuilt?
I say this, because getting a decent A-series these days that dosen't need a rebuild (whatever the seller says) is very difficult.
A crank regrind and a new set of bearings might be a better idea.
t3gav
Member #: 229
Gavin@minispares.com
kent
Don't forget the oil transfer pipe as well as the thread in the block is different, we do a kit (MOC1019) which is for the spi filter housing with pre 92 block. Personally i agree with Wil though.
quinton
Member #: 1911
Best way to get to know your car, rebuild the engine *wink*
Member #: 5638
Hi, Thankyou for the advice i recieved very much appreciated,my plan was to put a secondhand engine in while my original engine is rebuilt so thanks again.
mattwho
Member #: 6233
wellingbourgh
hi
not in the same boat but same engine!!
ive just got hold of a 94 mini cooper and the 1.3i engine feels ok but im not shure if its running right as i dont know any mini buffs near me lol
but what im after is that in thw inter im hopeing to turbo the engine with my dad as a lil project but im after info on what i can do now to get it moving in the hp direction? im after doing whats needed to gain power and to have it semi ready to turbo later on so i dont have to faf around at the time
i think the 1.3i is 62hp or something aint it? so help me get 63 lol
get stuck in and do the conversion; many of the traditional ways of getting more out your n/a engine will be pointless when you turbo it
do a search and see what comes up
ill be beaking an spi next week
mattwho
Member #: 6233
wellingbourgh
standerd?
mattwho
Member #: 6233
wellingbourgh
how much for the full engine
