Home > Introduce Yourself > hi all new bod here!!!!
minivan rick
Member #: 5645
middlesex ( near heathrow )
quick bit of info ; have minivan in rebuild new sills ,inner /outer a panels ( bloody mk1 a panels),door repairs all round . :( floor pan drivers side ,inner flithes .. have a rebuilt 998 to go in for now ,but have my metro turbo lump to go in as soon as i can rebuild it... (money , is everything !!)
now can anyone tell me if its worth putting the split brake system on with the 4 pot's as era turbo ,i have the metro still at hand for the unions and alike , i would like to use the type 4 master with servo but as the metro has three outs one for rear with the comp valve i was not sure were to add it ?
drive sharfts ? what ones etc
thanx all
rick
Don't go slow !!! Go Turbo :))))))
Hello and welcome
Welcome to TM
Welcome!!! pics? :)
minivan rick
Member #: 5645
will do ! pics coming soon
MarkGTT
Member #: 1194
Shropshire.
Welcome to TM
I have a split system, 4 pots, yellow tag master but no servo, with bulkhead pressure valve.. so can be done.. but as with everything there are more expensive and probably better options. e.g. 4 pots limit wheel size and add a bit of unsprung weight, but if you have it all to hand then fitting it has to be better than the original set up.
Welcom
