Home > Wanted > 14mmX1.5mm Socket Grub Screw
Im after some Metric Fine Grub screws and non of my local shops have any, ive searched the net but cant find any.
Does anyone know where i can get some?
Mike
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
I may have a few from my radio controlled car days. Is it M4 your after with a 1.5mm allen key fitting, yeah?
On 30th Apr, 2010 Rod S said:
Gary's description is best
Dunno. 14mm diameter. So M14
And 1.5 is the thread pitch.
Interesting - I just happen to be making an M14 X 1.5 boss at the moment (this metric fine size is used for a lot of IAT sensors) and am also after a blanking plug.....
..... along with M18 X 1.5 (also non-standard metric fine for lambda probes) and M12 X 1.5 (CTS sensors).
When I searched a while ago I found the M14 one is common on sump plugs, but these usually have a small flange so not strictly a grub screw. They are also used on compressed air systems and I did find a supplier selling blanking plugs - a grub screw but without the cone end - at about £1 but postage was £10.
Try phoning a few compressed air specialists unless you particularly need the "cone" end.
BTW, what's it for ???
PaulH
Member #: 2340
Dublin Ireland
blanking Oil galleries Id say
On 17th Feb, 2009 Rob H said:
PaulH youre correct! Ive phoned round loads of places and because i only want 4 there not interested!
Only other option is to Cut some bolts down and cut a slit in the top.
If it's blanking plugs (so don't need the cone end) phone compressed air specialists and ask for an M14 X 1.5 plug.... it is a common size for them. Same pressure rating, same hexagon recess, just a flat end instead of a cone end, which is what you want anyway.
Edited by Rod S on 26th Mar, 2009.
Nice one! Got some, good egg rod!
boostjunkie
Member #: 9117
Northampton
Any contact or links as I'm after a few myself :)
01smartc
Member #: 2563
Tamworth
I use these to blank oil galleries. Ive got about 100 in stock if you want some? Or just buy direct I guess
http://www.airlinkcompressors.co.uk/produc...metric-parallel
Chris
I have a bag of those form the link and to claim they are 14mm is a piss take, more like 13.6 mm dia, which makes for a very loose fit, so best to use a second tap and trial fit as you go for a best job,
carl
Yo-Han
Member #: 3228
North of the Netherlands
I got some from a 'hardwarestore' over here called Fabory, I googled it for UK:
http://www.fabory.nl/pages/home.html
Info on the package:
DIN906
steel MF
07660
140.150
Diameter is 14,0mm, slightly tapered to 13,8mm.
Pretty sure I should be able to source more if you can't get these.
Edit: sp, bloody foreigner
Edited by Yo-Han on 20th Aug, 2012.
Dazed and Confused....
boostjunkie
Member #: 9117
Northampton
Fantastic great response I have some on order, can't wait!
