| Home > Help Needed / General Tech Chat > MINI TURBO BALANCED PRESSURE BACK PLATE RACE | |||||||
41 Posts Member #: 5583 Member Cannock |
26th Mar, 2009 at 06:03:22pm
I have just brought a organic clutch kit and plan to buy a lighten fly wheel, due to my engine of being balanced and lightened, so it would be a waste, is this worth buying?
26th Mar, 2009 at 06:07:28pm
Any lightening and balancing of engine parts will be an improvement. It will certainly rev better. :) On 19th Jan, 2010 wil_h said:
26th Mar, 2009 at 06:17:18pm
What kind of money would a lighten back presure plate cost? |
26th Mar, 2009 at 06:26:56pm
Try the usual sources, MED, Swift Tune, Avonbar, Minispares or a titanium one from Force :) On 19th Jan, 2010 wil_h said:
26th Mar, 2009 at 06:35:34pm
Remember that this isn't balanced. You still need to balance it WITH your flywheel and clutch assy. Edited by Vegard on 26th Mar, 2009. On 13th Jul, 2012 Ben H said:
26th Mar, 2009 at 07:07:23pm
O I wasn't aware of that, you can buy a back plate brand new for pretty much the same price then, thankyou. |
26th Mar, 2009 at 07:40:14pm
The real question you should be asking is why the picture has been taken with the friction surface facing the bench so you cannot see it. On 26th Oct, 2004 TurboDave16v said:
26th Mar, 2009 at 08:13:59pm
On 26th Mar, 2009 Nic G said:
O I wasn't aware of that, you can buy a back plate brand new for pretty much the same price then, thankyou. A new one will also have to be balanced. On 13th Jul, 2012 Ben H said:
26th Mar, 2009 at 10:03:24pm
thats an old cast one, i would forget it.
26th Mar, 2009 at 10:25:48pm
On 26th Mar, 2009 BENROSS said:
thats an old cast one, i would forget it. and buy a minispares ultralight STEEL one there not exspensive How can you tell that's cast? So Ben, what are you using? :) On 13th Jul, 2012 Ben H said:
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
27th Mar, 2009 at 02:34:21am
can a macine shop balance a clutch,flywheel and backplate assembly without a crank? or does it all need to be done together? |
27th Mar, 2009 at 10:03:40am
some can, nomaly they will have a crank laying around thats allready balanced that they can bolt the flywheel on and get it on the machine. Depends how much mini stuff they do i guess.
27th Mar, 2009 at 10:22:46am
I left my flywheel/clutch in without a crank and they said they are able to do it fine. On 7th Nov, 2008 Nic said:
27th Mar, 2009 at 11:13:12am
On 27th Mar, 2009 Jay#2 said:
I left my flywheel/clutch in without a crank and they said they are able to do it fine. If they've got a piece of rod that the flywheel can bolt onto I guess it's allright. I have no idea on how they'll manage without. I always give them the primary gear and clutchplate as well. That is mandatory I've found. On 13th Jul, 2012 Ben H said:
27th Mar, 2009 at 07:10:12pm
I need to clarify what I said, they have a crank that they balance it on so what I mean is they might be able to do it even if you don't provide a crank. I gave them the clutch and all but not primary gear, never thought of that! On 7th Nov, 2008 Nic said:
