Home > General Chat > Bent valve..
giallofly
Member #: 164
The Stig..
Newport Pagnell
I thought i had blown the Head gasket at Combe out it turned out to be a bent exhaust valve on 4.
New one in place and ready to rock for the weekend!
Cheers to Mr Morspeed for doing some overtime to sort it out at such short notice..cheers Simon!
Edited by giallofly on 20th Oct, 2004.
dan
Member #: 93
excellent news
any particular reasons given for the valve bending? or was it just one of them random failures?
giallofly
Member #: 164
The Stig..
Newport Pagnell
No apparent reason, i have ran the same head deck clearances etc for along time, maybe the guide got to hot and gripped the valve. The piston did the damage but hardly a mark on the piston. A new 30mm stainless valve was fitted the the guide re-reamed to size..sorted!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
how weird!
Glad you got it sorted so fast!
What you up to this weekend?
Alex
AlexF
giallofly
Member #: 164
The Stig..
Newport Pagnell
Something for Charity mate!!
Combe...
good news jon, see you on the weekend my self, but my car will not be ready sorry.
minimark
Member #: 19
newcastle
very lucky !!
Was lucky but good that it was a nice easy fix.
Jon when your head was last off and the guides replaced did you have the seats professionally cut again?
I ask because I had the same thing Num 4 ex valve kept bending, (3 times in a row) this was I think because it wasn't seating in the seat 100% flat and was making the valve move to the side a little every time it seated, this in turn might have heated up the guide through the extra side loads on it and it made it stay open, and the piston came and bent it. As the valve was marked an pitted on one side, with the other side smooth like normal.
I say this as a few days after it happened again and I thought like you the guide was a little tight, so I had it machined out a little, as you can see it made NO difference.
