Home > Wanted > 3 dial gauges (110mph with RVC tacho)
Gaz
Member #: 2766
Banbury
Hi, has anyone got a 3 dial gauge set with 110mph speedo and RVC tacho going spare?
If so, how much do you want for it?
Gaz.:)
Coupe
Member #: 2178
Leyland, Lancs
I got a magnolia set out of a sportpack cooper - not sure what you mean by RVC though.
Gaz
Member #: 2766
Banbury
RVC is a the later type of voltage sensing tacho which works with the lower voltages of electronic ignitions. The older type (RVI) senses the high voltage spike from a dizzy / coil system. I'm looking for the RVC to work with MegaJolt.
The small print at the bottom of the tacho face 'should' say RVI or RVC.
...... fingers crossed.....
Coupe
Member #: 2178
Leyland, Lancs
I'll have a check for you pal when I can dig it out.
Gaz
Member #: 2766
Banbury
Not needed anymore, decided to go with an Acewell instead.
