| Home > Help Needed / General Tech Chat > O/T Audi A4 - Can't rev past 3500rpm | |||||||
461 Posts Member #: 91 Senior Member Live @ Worksop, Work @ Rotherham |
28th Mar, 2009 at 01:21:26pm
Hopefully someone on here maybe able to help. Tom??
28th Mar, 2009 at 01:26:22pm
change the fuel and air filter first, (fuel filter being the key) of that doestn sort it, its the MAF or a blockage in the exhaust . but my monies on the maf! as exhaust blockages (like particulate filter) usually get worse as the journey goes on.. running the tank low shouldnt cause any harm IMHO. i know people scaremonger about it but i run my diesel right down as do othe rpeople i know and none of us have had issues with lift pump failures or that. turbo 16v k-series 11.9@118.9 :)
28th Mar, 2009 at 02:31:16pm
MAF MAF MAF MAF MAF MAF MAF.
194 Posts Member #: 1297 Advanced Member Sunny Stockport |
28th Mar, 2009 at 03:31:22pm
MAF gets my vote. I've got a Golf and it did exactly the same thing when mine started playing up. Buy a genuine one (about 60 quid) rather than a pattern part as they tend to last longer, so I've been told. |
28th Mar, 2009 at 04:03:11pm
Cheers for the replies guys, it seems to point to the Maf, so heres hoping. I'll pick one up on Monday with a bit of luck. |
28th Mar, 2009 at 05:06:51pm
Or just take it to a dealer, it should still be under warenty.... On 11th Feb, 2015 robert said:
28th Mar, 2009 at 05:26:45pm
As others say. I have a comms lead so could try to plug it in and see what you get if you like?
28th Mar, 2009 at 05:34:45pm
I've got a black box for reading ecu's if you want to pop over and plug it in On 11th Feb, 2015 robert said:
28th Mar, 2009 at 05:52:00pm
problem is MAF failures often dont show up. only way to detect them is to have a known good reference to compare teh suspect maf with, either on file or physically :) if you have (for example) a choked exhaust or choked fuel supply, the maff will flatline when the engine goes flat, just as it would do if it had a duff maf. still, 99.9% chance its the maf :) turbo 16v k-series 11.9@118.9 :)
28th Mar, 2009 at 06:09:10pm
first mistake is trusting a main dealer! find a good specialist - I did and it hase saved me fortunes
28th Mar, 2009 at 06:16:42pm
Not under warranty any more due to the mileage.
28th Mar, 2009 at 06:38:13pm
but do make sure you find a good specialist, someone i now took their a3 tdi dsg to a german car specialist to have the dmf changed, the "specialist" stuck ordinary auto oil in the gearbox and fucked the whole box! its going to be nearly 6k to get it sorted.
On 28th Mar, 2009 Rob Gavin said:
first mistake is trusting a main dealer! find a good specialist - I did and it hase saved me fortunes sounds like the MAF though On 28th Aug, 2011 Kean said:
28th Mar, 2009 at 06:46:05pm
I use a place at meadowhall for mine. Just for servicing and stuff I can't (be bothered to) do myself On 11th Feb, 2015 robert said:
29th Mar, 2009 at 02:08:39pm
same problem i had with mine
Edited by wolfie on 29th Mar, 2009. Crystal Sound Audio said:
29th Mar, 2009 at 04:26:12pm
just clean the maf and give it a run.you wont be wasting any money then.
