| Home > Help Needed / General Tech Chat > LSD installation | |||||||
492 Posts Member #: 3684 Senior Member wisborough green west sussex |
29th Mar, 2009 at 05:09:25pm
i am thinking of getting a lsd to go with my straight cut box but i am unsure on how it works?, do you have to modify the gearbox at all to take it or will it just be a straight replacement with old standard diff???
29th Mar, 2009 at 05:16:04pm
You do have to grind out the diff housing to allow the diff to fit. Also, you would need a different crown wheel to fit the diff.
Gary's description is best |
29th Mar, 2009 at 05:23:13pm
ok thanks for the reply, also if i dont go for a LSD do you think i could just get away with an uprated diff pin for about 170bhp o should i just get a 4pin diff |
29th Mar, 2009 at 05:58:16pm
Definately, definately don't use a single pin diff. Use a minispares crosspin diff if your not going with an ATB or LSD. Appearantly the minisport cross pin diffs are shite (like all things minisport) On 12th Nov, 2009 Paul S said:
29th Mar, 2009 at 05:58:54pm
4 pin would be fine, as far as im aware there unbreakable, thing is with 170 bhp all ul have is the inside wheel spinning all the way up the road and as soon as you get to a corner the same again.
29th Mar, 2009 at 06:25:23pm
I have a Tran-x LSD, this required the gearbox casing to be ground to allow fitment. As Rick said, apparantly the ATB is a straight fit. |
29th Mar, 2009 at 07:26:38pm
ok great thanks guys ill look into atb then failing that 4 pin i think, if anyone has any of the following give me a shout... |
29th Mar, 2009 at 07:49:21pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=260453
On 17th Feb, 2009 Rob H said:
29th Mar, 2009 at 10:13:19pm
I have put my diff into the car, its basically the same as fitting a standard diff. Im waiting till tuesday to tax the car so will let you know how it goes! |
29th Mar, 2009 at 10:25:11pm
sweet looking forward to hearing results |
30th Mar, 2009 at 01:39:21pm
stick a quaife in, this will do the job and much better imo |
