| Home > Beginners Tech > Pre A Series (rather than A+) | |||||||
8 Posts Member #: 5688 Junior Member London |
30th Mar, 2009 at 09:24:37pm
As the title says,is it OK to use an Pre A Plus engine for a turbo build?
30th Mar, 2009 at 09:45:14pm
yep.
30th Mar, 2009 at 09:58:01pm
Appreciate the pistons (and head) will need changing, just wasn't sure if 'the block' would be ok. |
30th Mar, 2009 at 10:15:53pm
Block would be the same, but, fitting an A+ dizzy is a hassle. If going Megajolt or similar, there will be no issues. On 13th Jul, 2012 Ben H said:
31st Mar, 2009 at 12:32:40am
Assuming 1275, there is a void in the casting above the centre main bearing on "A" blocks which makes them weaker in that area.
31st Mar, 2009 at 12:36:11am
Thanks Rod for the advice, previous owner had already fitted the special bracket as has an alternator.
31st Mar, 2009 at 05:41:59am
On 31st Mar, 2009 Rod S said:
Assuming 1275, there is a void in the casting above the centre main bearing on "A" blocks which makes them weaker in that area. However, when I asked the question, the general view was that it is only a problem on high RPM motors and turbos usually are not built for high RPM. As well as the dizzy mount being different as Vegard says, you will need a special bracket to fit an alternator as the bosses on the front of the block are further across to take a dynamo. but 1000s came with a altenator as standard so chances are you have one allready. Infact didnt all 1275 'non coopers' come with one? |
31st Mar, 2009 at 06:49:05am
Assuming 1275, there is a void in the casting above the centre main bearing on "A" blocks which makes them weaker in that area. However, when I asked the question, the general view was that it is only a problem on high RPM motors and turbos usually are not built for high RPM. This depend on the block . There are a few blocks around which does not have that hole above the centre main bearing. |
31st Mar, 2009 at 07:32:48am
That hole most likely will improve horespower though! Edited by Vegard on 31st Mar, 2009. On 13th Jul, 2012 Ben H said:
31st Mar, 2009 at 08:25:40am
Its pretty easy to modify the dizzy to fit - pm if you want to know how. |
31st Mar, 2009 at 08:34:55am
indeed!
On 31st Mar, 2009 Vegard said:
That hole most likely will improve horespower though! On 28th Aug, 2011 Kean said:
31st Mar, 2009 at 04:00:57pm
Assuming 1275, there is a void in the casting above the centre main bearing on "A" blocks which makes them weaker in that area. However, when I asked the question, the general view was that it is only a problem on high RPM motors and turbos usually are not built for high RPM. As well as the dizzy mount being different as Vegard says, you will need a special bracket to fit an alternator as the bosses on the front of the block are further across to take a dynamo. but 1000s came with a altenator as standard so chances are you have one allready. Infact didnt all 1275 'non coopers' come with one? Maybe later ones but I have two early "A" 1275 blocks (with the hole above the centre main bearing) with bosses for dynamos :) All the differences are minor and can be worked around, and as blocks become scarcer, we'll all have to... Schrödinger's cat - so which one am I ??? |
