Home > Help Needed / General Tech Chat > 4 pots with the new wellers
clubman_dan
Member #: 142
Winchester
i have my metro four pots coming in the post soon and i was wondering, will they fit under a set of the new 10x5" wellers
the ofset is et +7mm (what ever the hell that means)
and the depth at the back of the rim is 79mm.
do you reckon 4 pots will fit under there with 7.9 discs??
cheers
DAN :)
Edited by clubman_dan on 21st Oct, 2004.
Kean
Member #: 341
aka T2clubby
South Staffs
probably yeah but you will have to reposistion the calipers if they are standard metro 4 pots
nutter driver
Member #: 47
Not very sunny swanage
should do i would have thought, this chap managed to get 8.4's under 10" wellers, so i would have thought 7.9's would be fairly easy. maybe.
http://www.richspeed.co.uk/Brake%20Modifications.htm
Pete
